Has the Higgs Boson Particle Been Discovered at Cern?
In summary: So while we're very excited about this, we're not at the stage yet where we can say with certainty that this is the Higgs boson. In summary, scientists at Cern are "99.99% certain" that they have found the Higgs boson particle. This could be a significant discovery, depending on its properties.
  • #106
What fundamental force does the Higgs field/particle belong to?
  • #107
A co-worker of mine who is a former Cern physicist tells me the the data and results announced so far provide no evidence of the parity of the boson yet. I looked over the slides of the presentations and saw nothing that indicated to me anything about parity. My co-worker claimed much more data and difficult analysis would be needed to establish the parity of the new particle.
Comments?
  • #108
None as far as I know.
  • #109
As I understand physicists are rather certain that Higgs boson (field) gives mass for W and Z bosons (they are linked with certain symmetry considerations).
But how "strong" is the idea that the same Higgs boson that gives mass for W and Z also gives mass for other particles?
  • #110
I don't think so. They said 4.9 sigma, they said that there is a new particle (again - 4.9 sigma) and that it could be the SM Higgs, but that they have to get more data and analysis to be sure about that; they said that there are decay channels looking like thew SM Higgs, but that there are others still to be investigated; so I think they were rather careful.
And what do you mean by "a lot of proof"? What do you expect?
  • #111
I myself am a little disappointed to see
six sigma is being used to prove a Physics Theory.
Has it been a normal practice in science this days?
  • #112
What do you think they've proven? Like it has been stated countless times in this thread before, the data that they have recorded at CERN appears to match what the Higgs boson should be. Nobody claimed that they have definitive proof that they found the Higgs boson with complete certainty.
Besides, it's 4.9 sigma, anyways. Not six.
  • #113
Statistical significance like 'x sigma' never proves a (physical) theory, it is to be seen as a significance of (the interpretation of) the results, i.e. that it's 'unlike to have occurred by chance'; it therefore provides some evidence (depending on x) to either ascept the hypotheses ('there is a particle') or to reject it ('there is something else, noise, ...').
You can never prove a physical theory! You can only try to disprove it and you will trust in the theory if it agrees with 'most' observations 'enough' attempts to disprove it have failed.
In particle physics they use 5 sigma, but of course they will collect more data and try to improve their analysis, so they will (hopefully ;-) report > 5 sigma in the next month or years
  • #114
another question
Would I be right to suppose that the Higgs Boson is believed to exist everywhere in the universe and with an even distribution?
In between galaxies as much as in the centre or at the surface of the earth?
Has anyone a link towards any theories ( in layman's language where possible) about the putative behaviour of this particle?
Is there any connection between the Higgs Boson and the graviton I sometimes hear tell of?
  • #115
No, the higgs field exists everywhere, there are not actual higgs bosons everywhere in the universe.
  • #116
Thanks .Well would this field be evenly distributed then in the same way as I was wondering about the particle- or might it be stronger in different regions of the universe than in others?
Or can the field be dynamic? Can it feed off interreacting particles and become stronger?
  • #117
Comments?
So then if we haven't the parity yet, nor the exact spin (other than it must be integer), objectively what we have so far is a very high chance to have found a new particle, not necessarily the SM Higgs, right? Maybe here is where all the media (and some scientists) hype might confuse the laymen.
So, basically everyone in the know expects this new particle to be the Higgs (or some Higgs), but just in case, what other SM (already observed or hypothesized) particles are compatible with what has been observed so far?
Meson?, Z-prime? graviton?...
  • #118
Not sure. Try searching the forum or google for the Higgs field. That may help you. Unless someone explains it before then of course.
  • #119
So if the tau decays remain low, could the significance using the same analysis fall, even if more data is collected?
Presumably though, since statistics are a matter of taste, common sense would say to use another analysis using only the relevant channels?
  • #120
ranrod said:
The 4.9 sigma refers to the data not being an error, but what are the odds that what was found is not a higgs boson? Didn't they say the spin is either 0 or 2? Does that mean a 50-50 chance it's NOT a higgs boson?
I am either president of the US or not. This does not imply a 50%-probability for both.@scijeebus: There is a new particle - this is nearly certain. While the 4-lepton-channel is a bit tricky, you do not get the 2-photon peak via (reasonable) measurement errors. The talks contained really strong evidence for the new particle. And it looks similar to the SM higgs boson.
Imagine someone tells you "I have the biggest diamond in the world"
... and you give this object to multiple independent experts (chosen by you and not revealed to him) to investigate it with several different methods. And all agree that it is a diamond and report its size. Sure, there is the possibility that all are wrong, but how likely is that?
tom.stoer said:
You may be right, the audience still does not understand what they are doing and they could invest more time in explanations.
Depends on the audience.
These questions do not make sense.
Right.
There are no other SM particles which could give this observation. There are some extensions to the SM which can have bosons in the mass range, usually somehow connected to the Higgs boson(s). But I do not know details here, I do not think any of them is realized in nature anyway :p.
  • #121
Please note my intention to practise politeness "may", "could", ... if you ask me the level of information is OK.
  • #122
Doesn't the first question make sense?
Is the higgs field the same everywhere in the universe?
Is there a higgs field in the middle of a supernova? (I am guessing no one knows about inside black holes)
  • #123
Please define "is".
It is the same everywhere, if "is" means its quantum-mechanical properties.
In a similar way, every electron behaves the same everywhere, but the question "is the electron the same everywhere" is not well-defined.
  • #124
How do we know what was found was really the Higgs?
The theory predicted a certain mass range in order for the wek force coupling to work out. Yet no "Higgs" could be found in that range. So they switched the range. So isn't there now a big problem with the weak force?
And what was found did not have the correct decay modes from the Higgs theory.
So something was found that does not seem much to resemble the putative Higgs.
  • #125
I guess you mean that no other particle is expected within the SM besides the Higgs.
And this much we all surely agree about.
Another question, does the SM Higgs boson have to be an elementary particle or it could be a composite boson and still be an SM Higgs?
I mention it because I'm reading physicist Matt Strassler' Higgs FAQ, and he says that since we know so little about the Higgs field: "we don’t know whether the Higgs is an elementary field, as is the electron field, or a composite of more elementary fields, as is the proton field."
  • #126
Can you give any source for that?
For example, look at the famous http://ppd.fnal.gov/conferences/nlc/minutes/000426.html (newer version). While 126 GeV is above the best fit, it is less than 2 standard deviations away.
Source? The tau channel has less events than expected, but it is within the statistic uncertainty.
  • #127
mfb said:
Please define "is".
Thanks.
Yes I think that is what I meant by "is" (not that I would recognise a quantum mechanical property unless it introduced itself politely first:rofl:)
So I mean if one was in a position to make a prediction on the consequences of an event anywhere at all in the universe would it be fair to say that this could not be done without including the effect of the Higgs field at that point in SpaceTime?
(although I suppose interactions between massless particles are unaffected by the field?-or am I betraying my ignorance again)
  • #128
"There are no other SM particles which could give this observation""
I don't know what "SM" means, but I doubt that matters.
The thing discovered decayed into 2 photons. A meson made of a quark and its own anti-quark, could decay into 2 photons--indeed the J/psi particle (made of a charmed quark and an anti-charm quark) decays into 2 photons. So how do we know that the new particle is not a combination of a very heavy newly encountered quark and its anti-partner?
  • #129
mfb, these are the best sources I can find on short notice.
Regarding the mass being off, the best I can find right now is the following from wikipedia (sorry about wikipedia)
<<The Standard Model does not predict the mass of the Higgs boson.[28] If that mass is between 115 and 180 GeV/c2, then the Standard Model can be valid at energy scales all the way up to the Planck scale (1016 TeV).[citation needed] Many theorists expect new physics beyond the Standard Model to emerge at the TeV-scale, based on unsatisfactory properties of the Standard Model.[citation needed] The highest possible mass scale allowed for the Higgs boson (or some other electroweak symmetry breaking mechanism) is 1.4 TeV; beyond this point, the Standard Model becomes inconsistent without such a mechanism, because unitarity is violated in certain scattering processes>>
Regarding decay modes, it is supposed to have an W+/W- mode (see link below) but this has not been observed for the new particle:
http://arxiv.org/abs/hep-ph/0608174
  • #130
Ooops, wrong quote from wikipoedia--serves me right for quoting wikipedia. This is what I wanted to quote:
<<In theory, the mass of the Higgs boson may be estimated indirectly. In the Standard Model, the Higgs boson has a number of indirect effects; most notably, Higgs loops result in tiny corrections to masses of W and Z bosons. Precision measurements of electroweak parameters, such as the Fermi constant and masses of W/Z bosons, can be used to constrain the mass of the Higgs. As of July 2011, the precision electroweak measurements tell us that the mass of the Higgs boson is lower than about 161 GeV/c2 at 95% confidence level (CL). This upper bound increases to 185 GeV/c2 when including the LEP-2 direct search lower bound of 114.4 GeV/c2.[27] These indirect constraints rely on the assumption that the Standard Model is correct. It may still be possible to discover a Higgs boson above 185 GeV/c2 if it is accompanied by other particles beyond those predicted by the Standard Model>>
  • #131
So why do you say that the mass is "wrong"? 125 GeV is certainly within the range of possible masses. This is also in the Wiki quote, so I don't see your point.
  • #133
kloptok , you are correct. I messed up on the quote--it's been a long day.
I do seriously remember reading that to make the weak force theory work out quantitatively correctly the Higgs boson had to be within a certain mass range. When it was not found there, they just went to a different mass range. Hopefully I can find a reference.
  • #134
As far as I know, a mass of 125 GeV is not a problem. What we knew before the LHC started was that the Higgs couldn't be too heavy because this would mess up other parameters (the Higgs enters other processes in loop corrections and if the mass is too high the values for these other processes don't agree with experiment), but then we're talking of masses on the order of 1 TeV and higher. Also, previous measurements from LEP and Tevatron excluded all masses below 115 GeV (LEP) and a band around ~160-175 GeV I think (Tevatron), see the exclusion plot below from February 2012 (note that the exclusion is today for the entire plot except just at 125 GeV where the line still is above 1, signifying the excess of events there). At the LHC one has looked for a broad range of Higgs masses, up to ~hundreds of GeV. I don't know exactly why but the region around 120 GeV is often quoted as the most difficult mass region to find the Higgs, which is probably why one left it for last since it would be easier to find the particle elsewhere. This might be wrong, but the difficulty to find it there might have to do with the fact that there are a lot of possible decays there, see e.g. the plot of branching ratio vs. higgs mass below. But as I said, this might not be the full story.
  • #135
SM=Standard Model
The SM contains three quark families. A forth family would be new physics and therefore beyond the SM. Apart from this:
- This quark would form other combinations, too. None of them was observed.
- It would have a mass of ~63 GeV, and therefore have been within the range of LEP (as the process e- e+ -> q anti-quark is quite likely, if the energy allows it) and Tevatron.
A high Higgs mass would have given some trouble.
However, at 126 GeV it is quite "boring" - if it is the Higgs, it is in the expected region.
About your second link:
The decay of a Higgs boson into a pair of W bosons h --> W^+W^-, is a dominant mode for Higgs boson masses above 135 GeV.
The discovered boson does not have a mass above 135 GeV. Below, the sensitivity of this channel is quite bad.
The decay channel b b-bar is dominant, and this has a lot of background. WW has the missing energy issue with neutrinos, gluon gluon is spammed by background, tau tau has the same neutrino issue again. The easier channels have a smaller branching fraction.
The observation is mainly based on the 2 photon channel now, with a branching fraction of a few permille.
  • #136
I would say the observation, at the same mass, of excess events consistent with H->Z,Z(*)-> 4 leptons, by both CMS and Atlas adds a great deal to the reliability of the finding, and the probability that it is 'Higgs like'.
  • #137
Vorde said:
Can someone explain to me how they know this particle is a boson?
A boson has integral spin. The photon and Z also have integral spins, so their sum must also. You might say, but what if there is an unseen fermion in the decay and it's really gamma+gamma+neutrino? The answer is that would be a 3-body decay and wouldn't give you a sharp peak: it would have a sharp right edge but extend down to 0. This would render it invisible to searches.
So it must be a boson, otherwise it wouldn't be observed.
  • #138
TrickyDicky said:
Thanks (I missed this was already answered in #77 and #78).
I know there is enough data to say it is an integer spin (boson), and that it is expected that it is 0 (scalar). How would it alter the state of things if it was found out its spin is 1 instead? Could it be the Higgs in that case?
A spin-1 particle cannot decay to two identical spin-1 particles. So the fact that it is seen in gamma+gamma precludes this.
  • #139
What's the highest mass possible for gravitons? if the ~126 Gev unknown particle detected In the LHC is not higgs.. and it's not gravitons.. what other particles have spin 0?
  • #140
atyy said:
So that would mean the CMS 5 sigma from the combination of 2 channels is illegitimate, as is the 5 sigma from ATLAS, since that seems not to have used all the relevant channels?
The ATLAS result used all channels from 2011, and all the channels where the analysis was finished from 2012. Only the two most sensitive channels were completed by July 4th.
The CMS result included two numbers: just the two most sensitive channels, and all the channels.
Each experiment has a significance of better than one in a million, so the overall probability is something like one in a trillion. At this level, I think it's fair to say that this is not a statsitical fluctuation. It might be a mistake, but it's not a statistical fluctuation.
