High quality mechanical pencil
  • Thread starter dipole
146
I recently have made the switch to mechanical pencils from old fashioned ones. I have to say I'm really enjoying them and my handwriting has improved (I used to write very hard and dark).
I find that I really enjoy this particular kind:
https://www.amazon.com/dp/B00006IEE4/?tag=pfamazon01-20
because I like the "twist to advance" mechanism, which also makes the lead break far less easily. I figure since I spend a good 20-30 hours a week writing on paper, I should just invest in a high-quality refillable mechanical pencil (I am aware its possible to refill the sharpwriters). I want one that is similar in design to the above ones, with a head that you twist to advance or retract the lead.
Any recommendations? I probably don't want to spend more than $20 on a pencil.
Evo
Mentor
22,873
2,349
I won't use anything but a mechanicl pencil, and I've used some very expensive ones over the years. I can't the say the expensive ones were that much better for writing. Is your use mostly for writing as opposed to drafting?
Maybe someone here will have found some great ones.
Dr Transport
392
Always us this, have had it for years and refuse to use another....0.9 mm lead
http://www.pentel.com/store/sharp-mechanical-drafting-pencil-3 [Broken]
146
Yea it's mainly just for writing. I just think it'd be nice to have a good quality one, I don't expect it to actually be more functional. Plus it feels bad throwing away plastic pencils when they're empty, a non-disposable pencil will feel nicer to own.
DaveC426913
1,908
I'd love to use a quality mechanical pencil. But I easily misplace things, especially writing implements. So I have to buy in bulk. I buy Bic pencils by the dozen.
61
I like the simple 0.5mm lead type mechanical pencils.
lisab
Staff Emeritus
616
High quality mechanical pencil? None here. How about moderate quality, affordable...and did I mention affordable :biggrin:?
Papermate Logo, 0.5mm. I don't know what hardness of graphite it comes with -- no matter, I go through them so fast. The refills I buy are HB. I go through a lot of graphite before I run out of eraser.
https://www.amazon.com/dp/B001B0B1O2/?tag=pfamazon01-20
Cheaper by the dozen!
Dipole, those pencils are the cats meow. I use them exclusively. I hate the clicky kind that don't let you adjust the lead length exactly. Instead you have to click, then hold, then press the lead in, then release and hope the thing doesn't suck the lead back up!
I haven't found anything better than those things. Plus they cost like 2 dollars for 10 at my local grocery store. The papermate logo is way expensive. I was burning through the yellow ones because I would toss it when the eraser was gone, but then switched to using a real eraser, external to the pencil, and it works great.
116
I only use these. I use them so much (and carry one with me at all times) that I go through 3 or 4 a year.
I have been considering buying a stronger pencil, but I haven't convinced myself that paying $30+ for one pencil is a reasonable investment.
turbo
45
I have quite a number of mechanical pencils, but my all-time favorite is a Caran D'Ache Fixpencil 2. It is always lying on the top of my desk and gets used in preference to markers, pens, etc. It is very old-school, but it is a wonderful instrument. It was the preferred pencil for sketching at the eyepiece when observing with a telescope. The larger lead (vs other mechanical pencils) didn't snag or poke through the paper when the paper got a bit soft during the night, and it's a whole lot easier to shade sketches vs smaller leads.
1,028
What does that rotating thing on there do? The thing that selects from B HB etc? How does the lead advance? Does the lead come out in an analog fashion, or is it a sort of quantized click?
Astronuc
Staff Emeritus
1,682
I used to use a Scripto P950 (0.5 mm). I should have bought several, but at the time, I bought one. The one I had finally broke.
Apparently Scripto doesn't make them (or other pencil products) anymore.
http://www.roger-russell.com/scripto2.htm
Prefer the clutch/click motion to rotating the tip to advance the lead. I use HB.
I now I use a Pentel Sharp™ Mechanical Drafting Pencil.
I have been using the same Staples mechanical pencil for years now. I bought a package of them so long ago that I can't remember. Whenever I used up the leads, I would take the leads out of a new one and fill the reservoir of the old pencil with them. However, at some also unremembered time in the past I bought a package of 24 Bic mechanical pencils. Enough for a couple of lifetimes. Just the other day I went to fill up my old Staples pencil again only to find that I had used up all of them and had none left. I went to replace the leads from the new Bics, only to find out that my old pencils were .7mm and the new ones are .5mm. I made a few marks with a new one to make sure I could withstand the change and found that I couldn't tell the difference. I don't know why I bought these Bic's though. It would have made a lot more sense to buy the leads.
Dembadon
89
Here's my test:
If the pencil pushes the lead out in such a way that when the lead is too short and one more click makes it too long, then the pencil is crap.
I'm using a $20 engineering mechanical pencil that I've had for about 3 years because I can get the lead to just the right length; not too short and not too long. It's also heavy so I don't have to press as hard on the paper.
537
mechanical pencils always turned me off because of their "high maintenance"
I'll stick with pens
6,171
1,275
Here's my test:
With the "clicker" depressed, you can push the lead back in to where ever you want it. I just click them out past where I want them, then depress the clicker and push them back.
Dembadon
89
Having to do that every time you need more lead doesn't annoy the hell out of you? What if you accidentally push it in too far? You have to do it all over again. It drives me nuts; I simply refuse to deal with such pencils! :grumpy:
This is something about which I'm unusually passionate. I can't explain why I get so aggravated over pencils, but I've had quite a few heated debates on this very subject with some of my classmates. :redface:
turbo
45
Zooby, I highly recommend that you get a Caran D-Ache Fixpencil 2 with relatively soft lead. Given your skills at sketching and your need for a pencil that excels at shading, I'm certain that you will be happy. Fixpencils are decidedly low-tech and durable and can be had for around $20 or so if you shop around. I love mine! If it were lost or stolen, I'd get another. No chance it will break - they are too simple and tough.
6,171
1,275
I already have a large number of clutch pencils, the kind draftsmen used to use, with a large variety of leads. I pick these up at the swap meet for a song, and have more than I actually use. The leads are 2mm. The great thing about these is the lead pointers: you can sharpen a clutch pencil sharper than any other kind. The drawback is they don't make leads for them softer than 5B, and those are hard to find. I have to resort to conventional art pencils for the 5B to 9B range of values.
turbo
45
I see. And yes, having a sharpener under the cap is a BIG plus. You can get one very fine point on a high-quality lead for fine work. I figured that you carried around sets of art pencils to do your art-work. You've already been there, done that with the clutch pencils. I've had mine for ~30 years. An advertising give-away from Proceq SA - manufacturer of non-destructive material testing equipment.
6,171
1,275
The included pointer is actually not very good and I always carry a separate lead pointer with me. They make small, plastic ones nowadays as opposed to the very heavy metal ones that used to be standard. These new ones are very portable:
http://www.dickblick.com/products/alvin-rotary-lead-pointer/
I actually carry a whole cigar box of pencils, all kinds of different ones, but I generally use the clutch pencils most because I have a range of lead hardness and they always stay the same length, as opposed to normal pencils which get shorter and shorter, obviously.
DaveC426913
1,908
It's sorta annoying, yeah. But while I agree, the dial-a-lead of the Papermates is a fine feature, I do not like the heft of them. They seem cheap and light. And the erasers suck (not that I use them - that's what my artgum wad is for)
A good heft is important.
6,171
1,275
No, it doesn't bother me. I use these kinds of pencils for both sketching and writing. I guess I'm over any inconvenience resharpening or reclicking presents.
Chi Meson
1,767
my pencil
http://www.dickblick.com/products/pentel-mechanical-pencil
There is a sleeve that comes out when the lead is advanced. The sleeve prevents the lead from breaking, and normal writing will cause the sleeve to retract as the lead is used up. Result, longer periods between advances.
The pencil is MUCH better than any disposables, but it doesn't cost too much. I don't know how much, because I've had the same one for about 15 years now.
I think this is the third time I've mentioned this on PF.
turbo
45
I have a lot of Pentels. My wife generally gloms onto them, but that's OK because I love my Fixpencil.
Related Threads for: High quality mechanical pencil
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
Hot Threads
