Find Nth Derivative of Square Root of X
In summary, you find the general formula for the nth derivative of x^1/2 (square root of x) by using the following steps:1) figure out the coefficients for each term in the derivative equation2) find a formula that works for the terms you have (factorials)3) prove by induction that the formula works for all n.
  • #36
0rthodontist said:
Data's expression is the same as HallsofIvy's.
your right...why didnt it work the first time i tried it? :confused:
dont know what i did. i think i substituted wrong or something.
  • #37
Halls is HallsofIvy
  • #38
lol. i was thinking halls was some calc theorem :)
  • #39
occasionally an apparently useless thing (like, say, multiplying by 1, which is all I did) can allow you to avoid splitting things up into ugly "special cases"
  • #40
Data said:
yes, it's the same except that you can still evaluate it for [itex]n= -1[/itex] (even though the "product of the first 0 odd integers" doesn't make any sense). It happens to give dnt exactly what he needs though~
Ah, good idea.
I do think it would have been easier to generalize from example (continuing from before, at the fourth derivative):
[tex](-1)^3 \frac{6!}{(3!)(2^7)} \cdot x^{-\frac{7}{2}}[/tex]
Now you know that you're going to change the sign every time, so the exponent on -1 is going to increase by 1 every time. The 6! came from 5 * 3 * 1 so that is going to increase by 2 every time. The 3! will increase by 1 every time, and the exponent on the 2 will increase by 1 every time from 5 * 3 * 1 and by another 1 every time from the denominator. So you can then write
[tex](-1)^{n - 1} \frac{(2 * (n - 1))!}{((n-1)!)2^{2n - 1}} \cdot x^{\frac{1}{2} - n}[/tex]
where all I did was make sure the various terms increase as they should, and otherwise adjust them by constants so they match the example. This saves you some fiddling with off-by-one errors and then you can verify it with more general notation.
  • #41
HallsofIvy said:
Also, your statement that "the numerator part goes 1,-1,-3,-5" is wrong.
What you put in your very first post was:
n=1 (1st der): (1/2)(x^-1/2) = (1/2)(x^(-1/2))
n=2 (2nd der): (1/2)(-1/2)(x^-3/2) = (-1/4)(x^(-3/2))
n=3 (3rd der): (1/2)(-1/2)(-3/2)(x^-5/2) = (+3/8)(x^(-5/2))
n=4 (4th der): (1/2)(-1/2)(-3/2)(-5/2)(x^-7/2) = (-15/16)(x^(-7/2))
(I've added the last in each line.)
so the numerators are 1, -1, 3= 1*3, -15= -1*3*15.
It might help you to realize this:
A product of even integers is 2*4*6*...*2n= (2*1)(2*2)(2*3)...(2*n)= (2*2*2...2)(1*2*3*...n)= 2nn!.
A product of odd integer, 1*3*5*7*...*(2n+1) is missing the even integers: multiply and divide by them:
[tex]\frac{1*2*3*4*5*...*(2n)*(2n+1)}{2*4*6*...*(2n)}= \frac{(2n+1)!}{2^n(n!)}[/tex]
i konw the problem has been solved but i wanted to make sure i really understood it and one more question about the above equation popped into my head.
in regards to that numerator (product of the first n integers) how does it equal (2n+1)! ?
eg. if n=5 (product of first 5 integers = 1*2*3*4*5), well that should be equal to 120 which is n!
if you use (2n+1)! you get 11!, a much bigger number. can someone reexplain that? thanks.
  • #42
can anyone explain it?
thanks.
  • #43
it doesn't. (2n+1)! is the product of the first 2n+1 integers, of course, not the first n integers.
But [itex](2n+1)!/(n!2^n)[/itex] is the product of the first [itex]n+1[/itex] odd integers, because you're multiplying together the first 2n+1 integers and then dividing out the even ones. Here [itex]n!2^n[/itex] is the product of the first n even integers:
[tex]n!2^n = n(n-1)...(1)*2^n = (2n)(2n-2)...(2).[/tex]
So in [itex](2n+1)!/(n!2^n)[/itex], you're multiplying together the first [itex]2n+1[/itex] integers in the top, then you divide out the first [itex]n[/itex] even integers in the bottom, leaving you with the first [itex](2n+1)-n = n+1[/itex] odd integers!
