Higher Spin Field Rep: Tr(n,n)=0, Why Symmetric Tensor of Rank 2n?
  • I
  • Thread starter filip97
  • Tags
    Field Spin
In summary, (n,n) is a symmetric tensor of rank 2n because it is composed of n copies of a symmetric tensor (1,1). This can be seen through the definition of a symmetric tensor and the fact that (n,n) is a direct sum of n copies of itself. Additionally, the trace of (n,n) is zero due to the trace of a direct sum being the sum of the traces of each individual tensor. This was explained by Weinberg in his book Vol. 1 page 231.
filip97
31
Representation
(n,n)=nxn=2n+(2n-1)+...+2+1 , where + is direct sum, and x is tensor product. Trace of (n,n) is zero because tr(k) is zero, where k=1 to n. But why tensor (n,n) is symmetric tensor of rank 2n? I read Weinberg book Vol. 1 page 231. But he don't clearly says this .
Hello! Thank you for bringing up this interesting topic about representation theory. I will try my best to explain why (n,n) is a symmetric tensor of rank 2n.
First, let's define what a symmetric tensor is. A symmetric tensor is a tensor that remains unchanged under the exchange of its indices. In other words, if we swap the positions of two indices, the value of the tensor remains the same. For example, in a 2x2 matrix, the value at position (1,2) is the same as the value at position (2,1).
Now, let's take a closer look at the tensor (n,n) = nxn = 2n+(2n-1)+...+2+1. This tensor is the direct sum of n copies of itself, which means it is a tensor product of n copies of (1,1). Therefore, (n,n) is a symmetric tensor of rank 2n because it is composed of n copies of a symmetric tensor (1,1).
Moreover, we can also see that the trace of (n,n) is zero, as you mentioned. This is because the trace of a direct sum is the sum of the traces of each individual tensor. Since the trace of (1,1) is zero, the trace of (n,n) will also be zero.
I hope this helps to clarify why (n,n) is a symmetric tensor of rank 2n. If you have any further questions or would like to discuss this topic more, please feel free to continue the conversation. Thank you!
1. What is a higher spin field?
A higher spin field is a type of field in theoretical physics that has a spin greater than 2. Spin is a quantum mechanical property that describes the intrinsic angular momentum of a particle or field.
2. What does Tr(n,n)=0 mean in the context of higher spin fields?
Tr(n,n)=0 is a mathematical condition that the symmetric tensor of rank 2n must satisfy in order to be considered a higher spin field. This condition ensures that the field is traceless, meaning that the sum of its diagonal elements is equal to zero.
3. Why is the symmetric tensor of rank 2n important in higher spin fields?
The symmetric tensor of rank 2n is important because it is the mathematical object that describes the properties of a higher spin field. It contains all the necessary information about the field's spin and other physical characteristics.
4. What is the significance of the symmetric tensor being symmetric in higher spin fields?
The symmetry of the tensor is important because it ensures that the field is invariant under certain transformations, such as rotations and translations. This is a fundamental property of all physical fields and is necessary for the consistency of the theory.
5. How does the symmetric tensor of rank 2n relate to other fields in physics?
The symmetric tensor of rank 2n is a generalization of the symmetric tensor of rank 2, which is used to describe spin-2 fields like the graviton. In this sense, it is a more complex and higher-dimensional version of the familiar fields in physics, and it is used to study more exotic phenomena in theoretical physics.
  • Quantum Interpretations and Foundations
  • Classical Physics
9K
