Solving Holomorphic Function: Is f(z) Differentiable at z_0?
  • Thread starter latentcorpse
  • Tags
    Function
In summary, f(z) = (\bar{z})^2 is not holomorphic on the whole complex plane, except at the origin. The complex derivative at the origin is 0, and the function f is not differentiable at any other point in the complex plane.
latentcorpse
1,444
Is f(z) = [itex](\bar{z})^2[/itex] holomorphic in [itex]\mathbb{C}[/itex]? Is it differentiable in the complex sense at any point [itex]z_0 \in \mathbb{C}[/itex]? If it is, find [itex]f’(z_0)[/itex].
for the first part i said it was not holomorphic on the whole complex plane as [itex]f(z)=(x-iy)^2=x^2-2ixy-y^2=u(x,y)+iv(x,y)[/itex]
and so [itex]\frac{\partial{u}}{\partial{x}}=2x,\frac{\partial{u}}{\partial{y}}=-2y,\frac{\partial{v}}{\partial{x}}=-2y,\frac{\partial{v}}{\partial{y}}=-2x[/itex] meaning the Cauchy Riemann equations are not satisfied unless [itex](x,y)=(0,0)[/itex] i.e. it is holomorphic at the origin of the copmlex plane and therefore it may be differentiable at this point - this leads us to the next part of the question.
so for f to be differentiable at a particular [itex]z_0 \in \mathbb{C}[/itex] it must be holomorphic at that point, let us investigate what happens at [itex]z_0=(0,0)[/itex]
[itex]\mathop {\lim }\limits_{h \to 0} \frac{f(z_0+h)-f(z_0)}{h} = \mathop {\lim }\limits_{h \to 0} \frac{f(h)}{h}=\mathop {\lim }\limits_{h \to 0} \frac{\bar{h}^2}{h} \rightarrow 0[/itex].
now as this limit exists, f must be differentiable at 0
the derivative is given by [itex]f'(z)=\frac{\partial{u}}{\partial{x}}+i \frac{\partial{v}}{\partial{x}}=0[/itex]
i'm a little uncertain of the final answer so would like someone to check over my working if possible. cheers.
You are right, the complex differential exists only at the origin and it is 0. By the way, since you alread computed the partial derivatives and found the Cauchy-Riemann equations to be satisfied at 0, this already implies that the complex derivative (i.e. the limit of the difference quotient) exists at 0.
However, the definition of "holomorphic" requires an open set U of the complex plane and the complex derivative to exists for all points in U. Otherwise the familiar properties, like existence and convergence of the taylor series, would fail. So it does not make sense to say that f is holomorphic at the origin, since a single point is not open.
1. What does it mean for a function to be holomorphic?
A holomorphic function is a complex-valued function that is differentiable at every point in its domain. This means that the function has a well-defined derivative at every point, and the derivative is also a complex number.
2. How do you determine if a function is differentiable at a specific point?
To determine if a function is differentiable at a specific point, we use the Cauchy-Riemann equations. These equations state that if a complex-valued function f(z) = u(x,y) + iv(x,y) is differentiable at a point z = x + iy, then the partial derivatives of u and v with respect to x and y must exist and satisfy the equations:
∂u/∂x = ∂v/∂y and ∂u/∂y = -∂v/∂x
3. What is the significance of the Cauchy-Riemann equations in solving holomorphic functions?
The Cauchy-Riemann equations are necessary conditions for a function to be differentiable at a point. This means that if a function satisfies these equations at a point, it is also differentiable at that point. These equations also help us determine if a function is holomorphic.
4. Can a function be differentiable at a point but not holomorphic?
No, a function cannot be differentiable at a point but not holomorphic. If a function is differentiable at a point, it must also satisfy the Cauchy-Riemann equations, which are necessary conditions for holomorphicity. Therefore, if a function is differentiable at a point, it is also holomorphic at that point.
5. Are there any other methods for determining if a function is differentiable at a point?
Yes, there are other methods for determining if a function is differentiable at a point, such as using the limit definition of a derivative or using the Wirtinger derivatives. However, the Cauchy-Riemann equations are the most commonly used method for solving holomorphic functions and determining differentiability at a point.
