Can I Make a Homemade Electric Bicycle Using Parts from Broken Appliances?
In summary: presumably you'll want to maximize the distance traveled on one recharge, so this means you replace the power-wasting variable resistor...
tatertoph
I started learning solidworks at my school and got this idea for a folding bicycle as I need one and they're really expensive. I was planning on modeling it after a montague paratrooper bike. Then I thought I could put an electric motor on the rear wheels either by a sprocket or by just putting a metal bar up against the tire that could help spin the wheel (which would be easier but less efficient).
My question is though does anyone have some ideas on a cheap motor i could get from like a broken appliance. So far my thoughts are a washing machine or electric weed whacker.
Also what are your thoughts on somehow recharging the battery? I thought about attaching a car alternator to the rear wheel. Although I'm not positive if the wheel would be moving at enough RPM's to get any sort of output to recharge the battery (probably a 12v quad battery).
Just looking for some thoughts or advice Thanks
hey,
Cool project!
I've taken apart a few electric weed whackers (to get the motor out of them) and i can tell you that they won't be strong enough to move a bike.
I don't know much about a washing machine's motor, but my guess is that it might be too bulky?
id try using a starter motor. the one on my riding lawnmower launched itself out of the engine one day, so its pretty powerful, and its pretty compact. So i think that would make a good motor to help out with your pedaling. However, I've heard that they arnt supposed to be run for extened periods of time because they might over heat. So if you do use one make sure its very well ventilated (having air flow inside the motor case will help also).If you manage to snag a brush-less DC motor (or most AC motors) you'll be all set for recharging your battery. all you'd have to do is set up a circuit to redirect the electricity generated from the motor itself into that battery, change it from AC to DC (pretty easy with a few diodes) and boom! your recharging on the downhills. An easy way to tell if the motor will work is to check if it has real magnets inside. if it does it should work just fine.
hope this helps :)
(oh I just randomly found this cite so not sure if ill answer any questions asked cause i probably won't check this again...yaa...GOOD LUCK :D )
For the record: you cannot effect the recharge of a battery while simultaneously drawing from it the power to do so. It is not clear whether that may be your plan, or not.
Forget about having a second device to use as a generator while coasting downhill, this is inefficient and needlessly complicated. When an electric bike goes downhill, the motor gets rotated by the wheels so acts as a generator itself—you don't need a separate generator to reclaim some of the downhill kinetic energy and put it back into the battery. Though you will need a smart controller to oversee all this.
Ya, i guess I didnt make that very clear, but that's what i meant. The electric motor that powers the bike would charge the battery on the downhills. And depending on how you set the circuitry up you wouldn't need a controller. All you'd need to do is set up a variable resistor switch to control how fast you go, then use a bunch of diodes to control how the electricity flows. So when the controller switch is off the electricity generated from the motor gets converted to DC and charges the battery.
Presumably you'll want to maximize the distance traveled on one recharge, so this means you replace the power-wasting variable resistor arrangement with a power-saving electronic controller, and the rest is as I stated.
The traditional way of setting up an e-bike is to use a three phase permanent magnet BLDC motor. In that case you use an electronic speed controller (ESC) that controls motor output using PWM. Motors like this are common and you can even make them yourself; http://www.gobrushless.com Though for regenerative braking you need a controller that supports it so that might be a limitation in finding a suitable motor controller.
Power supply would typically be a bank of ten or more LiFeP04 cells for 32V nominal and higher. These cells are easy to find either in a steel cased round cell or prismatic pouch. They are a bit pricey but they have the best cycle life and highest charge/discharge rates. They're also one of the lighter and more compact types of batteries. The best ones come from A123 Systems; http://www.a123systems.com/
Right, wasnt thinking about the power loss from the resistor.
1. How do I make a homemade electric bicycle?
To make a homemade electric bicycle, you will need a regular bicycle, an electric motor, a battery, a controller, and some basic tools. First, attach the motor to the rear wheel of the bicycle. Then, connect the motor to the battery and the controller. Finally, attach the controller to the handlebars and test the electric bicycle to make sure it is functioning properly.
2. How fast can a homemade electric bicycle go?
The speed of a homemade electric bicycle will depend on the power of the motor and the weight of the rider. Generally, a homemade electric bicycle can reach speeds of 15-20 miles per hour.
3. How far can a homemade electric bicycle travel on a single charge?
The distance a homemade electric bicycle can travel on a single charge will depend on the battery capacity and the terrain. On average, a homemade electric bicycle can travel 20-30 miles on a single charge.
4. Is it legal to ride a homemade electric bicycle on the road?
The legality of riding a homemade electric bicycle on the road will vary depending on your location. In some places, electric bicycles are considered motor vehicles and require registration, insurance, and a license to operate on the road. It is important to check your local laws and regulations before riding a homemade electric bicycle on the road.
5. Can I convert any bicycle into an electric bicycle?
Most bicycles can be converted into an electric bicycle, but some may be easier to convert than others. Bicycles with a sturdy frame, good brakes, and a strong rear wheel are typically better candidates for conversion. It is also important to make sure the bicycle can support the weight of the added electric components.
  • DIY Projects
  • Electrical Engineering
  • Mechanical Engineering
27K
