Homework Help: Homework: Coulomb's Law
  1. Jan 14, 2014 #1
    A point charge q1 = -3.9 μC is located at the origin of a co-ordinate system. Another point charge q2 = 7.3 μC is located along the x-axis at a distance x2 = 7.8 cm from q1.
    1) What is F12,x, the value of the x-component of the force that q1 exerts on q2?
    2. Relevant equations
    F=(k*q1*q2)/r^2
    3. The attempt at a solution
    [(-3.9*10^-6 C)*(7.8*10^-6 C)*(9*10^9 C)]/(0.078^2) m= -45 N
    but the answer is wrong I converted everything into metric units.
  3. Jan 14, 2014 #2
    Simon Bridge
    Converting to SI units can simplify things, but if you are frequently using different units it can work out better to convert the constants instead.
    k=89.876N.cm2/μC2
    I think you just had some rounding issues ... I'm getting a slightly different number off the same calculation.
  4. Jan 14, 2014 #3
    when I used your k value with no conversions I got -42.1 N. I guessed the program wanted a more accurate solution thanks.
  5. Jan 15, 2014 #4
    Simon Bridge
    When I used yours - I got 42.115N and mine got me 42.057N ...
    With conversion the calculation works out as:
    90*3.9*7.3/7.8^2 = 42.115
  6. Jan 15, 2014 #5
    must have been the order with my calculator . I have a ti-30x IIS which is harder to track parenthesis and slightly longer operations. thanks again
  7. Jan 17, 2014 #6
    lightgrav
    depends on whether q2 = 7.3 μC , or 7.8 μC .
Have something to add?
Draft saved Draft deleted
