How Does Grain Size Influence Strength in Space-Centric Cubic Metals?
In summary, the conversation was about a question related to a job in a material science course. The moderator reminded the user to post homework in a designated forum with a proper title and to follow the template. They also emphasized the importance of showing one's own attempt at solving the problem before receiving hints from helpers. The user was specifically seeking help with showing the transition from a type 2 crash to a type 3 cogometry function in a diagram for a space-centric cubic metal.
jimis09
<<moderator: moved from a technical forum, no template>>
Hi ...
I have a question about a job in the material science courseWe give the hall petch type that denotes the dependence of the strength on the average grain diameter d, also has a value close to 1mpa. I have to show in a diagram σ-d ^ 1/2 the transition from type 2 crash to crank type 3 cogometry function for a space-centric cubic metal
In the future, homework must be posted in a homework forum, and you must fill out the template. Threads also need a more informative title than, "homework help"
Most important, the helpers aren't allowed to just give the answer. You must show your attempt at solution first, and then they'll give hints.
So please begin by showing us how you would try to solve the problem.
1. What is space-centric cubic metal?
Space-centric cubic metal is a type of crystal structure commonly found in metals. It is characterized by a lattice structure where each atom is surrounded by 8 other atoms, forming a cube shape. This structure is also known as face-centered cubic (FCC) or cubic close-packed (CCP) structure.
2. How is space-centric cubic metal formed?
Space-centric cubic metal is formed through a process called solidification, where the molten metal is cooled and arranged into a lattice structure. This structure is the most energetically favorable arrangement for metal atoms, making it the most common crystal structure for metals.
3. What are the properties of space-centric cubic metal?
Space-centric cubic metals have high ductility and malleability, making them easy to bend and shape without breaking. They also have high thermal and electrical conductivity, making them useful in applications such as wiring and electrical components. Additionally, FCC metals have a close-packed structure, making them relatively dense and strong.
4. What are some examples of space-centric cubic metals?
Some common examples of space-centric cubic metals include copper, gold, silver, aluminum, and nickel. These metals are widely used in various industries due to their desirable properties such as conductivity, strength, and corrosion resistance.
5. How is space-centric cubic metal different from other crystal structures?
Space-centric cubic metal differs from other crystal structures such as body-centered cubic (BCC) and hexagonal close-packed (HCP) in terms of atom arrangement. In BCC, each atom is surrounded by 8 other atoms, forming a cube with one atom at the center. In HCP, the atoms are arranged in a hexagonal pattern. Additionally, FCC metals have the highest packing density among the three structures, making them more malleable and ductile.
  • Mechanical Engineering
  • Science and Math Textbooks
17K
