Homogeneous equations
  • Thread starter magnifik
magnifik
360
i am having trouble trying to classify whether or not a differential equation is homogeneous.
i know that if it is, f(tx, ty) = tnf(x, y)
but i don't really know what this means
for example,
why is f(x, y) = exy not homogeneous
but f(x, y) = ex/y is homogeneous??
does that mean a function like
f(x, y) = ex/y dx + 3 dy would be homogeneous?
Answers and Replies
vela
Staff Emeritus
Education Advisor
15,566
2,204
for example,
Because f(tx, ty) = e(tx)(ty) = et2xy ≠ tn exy = tnf(x,y) for any value of n.
Because in this case f(tx, ty) = e(tx)/(ty) = ex/y = t0f(x,y)
That doesn't really make sense.
magnifik
360
how does it not make sense? :\ that's an example in my textbook for a homogeneous differential equation
fzero
290
The term "homogeneous" is used in a slightly different way in the case of linear differential equations. A linear differential equation for a function y(x) is called homogeneous if it is invariant under the rescaling transformation y(x) -> t y(x). This means that an equation
[tex] a_n (x) \frac{d^ny(x)}{dx^n} + \cdots + a_1(x) \frac{dy(x)}{dx} +a_0(x) y(x)= f(x)[/tex]
is homogeneous only for [tex]f(x)=0[/tex].
The usage isn't completely different from the one for functions, since homogeneity still refers to a behavior under a rescaling. But for ODEs it does not involve a rescaling of the coordinate x.
vela
Staff Emeritus
Education Advisor
15,566
2,204
I'd be surprised if it was written in your textbook exactly as you wrote it here.
Here are some web pages that explain homogeneous differential equations:
http://www.cliffsnotes.com/study_guide/First-Order-Homogeneous-Equations.topicArticleId-19736,articleId-19713.html [Broken]
http://www.tutorvista.com/math/solving-homogeneous-differential-equations [Broken]
What they say is the differential equation
M(x,y) dx + N(x,y) dy = 0
is homogeneous if M(x,y) and N(x,y) are homogeneous functions of the same degree. So in the differential equation
ex/y dx + 3 dy = 0 [not f(x,y)]
you have M(x,y) = ex/y and N(x,y) = 3. Both functions are homogeneous functions of degree 0, so the differential equation is a homogeneous differential equation.
You can transform such an equation into a separable one by using the substitution y=xv.
Note that fzero's post explains the usual meaning of "homogeneous differential equation." I'm assuming you're referring to the less common meaning based on your question about homogeneous functions of degree n.
magnifik
360
can a homogeneous differential equation be exact?
fzero
290
Sure, the functions M(x,y) and N(x,y) from vela's post must still be homogeneous functions of the proper degree and must also satisfy
[tex] \frac{\partial M}{\partial y} = \frac{\partial N}{\partial x} .[/tex]
The potential function will be homogeneous of one degree higher.
Suggested for: Homogeneous equations
  • Last Post
  • Last Post
  • Last Post
  • Last Post
