Homework Help: Homogeneous topological space
  1. Nov 12, 2009 #1
    For any [itex] a \in \left( -1,1 \right) [/itex] construct a homeomorphism [itex] f_a: \left( -1,1 \right) \longrightarrow \left( -1,1 \right) [/itex] such that [itex] f_a\left( a \right) = 0 [/itex]. Deduce that [itex] \left( -1,1 \right) [/itex] is homogeneous.
    2. Relevant equations
    Definition of a homogeneous topological space, ie that the exists a homeomorphism for each pair of points x,y which maps x to y.
    3. The attempt at a solution
    I can't find a set a functions which map an arbitrary point to zero and is surjective. My attemps include f = x - a, f = |x - a|, f = sin (x-a) but these are not homeomorphic for arbitrary a.
  3. Nov 12, 2009 #2
    George Jones
    Staff Emeritus
    There are lots of such homeomorphisms. Examples:
    1) join two straight lines that have different slopes (not necessarily equal to one);
    2) use the points (-1, -1), (a, 0), and (1, 1) to pin down a parabola (I think this works, haven't worked the details).
  4. Nov 12, 2009 #3
    I'd be careful with the parabola idea, since if it actually has a peak in that interval, then it won't take open sets to open sets, but will take any open set that contains the x-value for the axis of symmetry to a half-open set.
  5. Nov 12, 2009 #4
    George Jones
    Staff Emeritus
    Yes, that's why I said that I think it works. I drew some sketches that make it appear that the max/mins occur outside the interval, but I didn't solve any equations. My sketches could be misleading me.
    Obvious choices of line segments in my example 1) give obvious homeomorphisms.
  6. Nov 12, 2009 #5
    Can you explain what you mean by joining lines? Are you talking about intersecting lines in [tex] R^2 [/tex]?
  7. Nov 12, 2009 #6
    George Jones
    Staff Emeritus
    Yes.
    What are [itex]A[/itex] and [itex]B[/itex] such that [itex]f_a \left( x \right) = Ax + B[/itex] has
    [tex]\lim_{x \rightarrow -1} f_a \left( x \right) = -1[/tex]
    and [itex]f_a \left( a \right) = 0[/itex]?
  8. Nov 12, 2009 #7
    Right so you have a line starting at the point (-1,-1) and intersecting at (a,0). Unfortunately it does not finish at (1,1), and so it cannot be a bijection from the interval
    (-1, 1) to (-1,1). Is this not right?
  9. Nov 12, 2009 #8
    It can be a bijection so long as the lines are both increasing or both decreasing.
  10. Nov 12, 2009 #9
    Sorry I must be confused here. I can only see one line other than the interval (-1, 1). I thought you were talking about a line crossing the real axis at the point a.
  11. Nov 12, 2009 #10
    George Jones
    Staff Emeritus
    So pick another line from (a,0) to (1,1), and turn f_a into a "schizophrenic" function.
  12. Nov 12, 2009 #11
    ok so I have for x < a [tex] f_a \left( x \right) = \frac{x-a}{1+a} [/tex]
    and for x > a [tex] f_a \left( x \right) = \frac{x-a}{1-a} [/tex]
    Which coincide at x = a. Looks good to me.
  13. Nov 12, 2009 #12
    George Jones
    Staff Emeritus
    Looks good if an equality is included for at least one of x < a, x > a.
    The question is not done yet, though. You still need to show the deduction that gives that (-1, 1) is a homogeneous space.
  14. Nov 12, 2009 #13
    I know I was just thinking about that. I need to show that for any x,y in the domain, there is a homeomorphism mapping x to y. Presumably I can somehow use the function I just made, but simple addition of y onto this function doesn't make a homeomorphism.
  15. Nov 12, 2009 #14
    George Jones
    Staff Emeritus
    Unfortunately, I know only how to give a very small hint, or a very large hint (writing down the answer). Small hint: since both x and y are arbitrary elements of (-1 , 1), you should try things that have both x and y as indices.
    Maybe someone else knows a better hint that doesn't give the whole answer away.
  16. Nov 12, 2009 #15
    How about this:
    [tex] f_b \left( b \right) = 0, f_a^{-1} \left( 0 \right) = a, f_a^{-1} \left( f_b \left( b \right)\right) = a [/tex]?
    So that for any a,b we have a homeomorphism (i think) mapping b to a.
  17. Nov 12, 2009 #16
    George Jones
    Staff Emeritus
    Yes, that's it. :smile:
    I might switch the and b around in one of the places, i.e., either "So that for any b,a we have a homeomorphism," or [itex]f_b^{-1} \left( f_a \left( a \right)\right) = b
    [/itex].
  18. Nov 12, 2009 #17
    Ok thanks that's the problem solved!
Loading...
