Homopolar Motor Power
Summary:
Energy input and output
I was curious in regards to a homopolar motor where the energy imparted into the rotor comes from if the energy input is say 10v at 1000 amps and there is 10v 1000amps output. Aswell if the effect of the magnetic field produces a different power on the rim of the disk vs the input from the central rod.
Answers and Replies
Nugatory
Mentor
12,952
5,644
The input power comes from whatever we are using to drive a current through the loop of the motor.
How are we getting an output from the motor? Using it to drive a generator? In any case the output power will be less than the input; if we are passing 1000 amps at 10 volts through the loop of the motor, then its usable output must be less than 10kW.
(And as a practical note, a sustained 1000A current is a big scary dangerous thing - I hope that you are doing a thought experiment here, not planning to actually build something).
Likes berkeman, sophiecentaur and davenn
Thanks for your reply.
The question had more to do with if any of the power through the motor gets absorbed and turned into kinetic energy and if say there where 2 current and voltmeters on where the input is passed verse to where the output is taken from the rim of tge disk if the current and or voltage when being read on the output would be altered at due to said absorbtion or some other effect.
Im assuming from your answer the power on the side where current flows out of the disk stays just 10kw. Can you clarify that please?
berkeman
Mentor
57,952
8,027
The question had more to do with if any of the power through the motor gets absorbed and turned into kinetic energy and if say there where 2 current and voltmeters on where the input is passed verse to where the output is taken from the rim of the disk if the current and or voltage when being read on the output would be altered at due to said absorbtion or some other effect.
Yeah, for an ideal motor/generator, the power output equals the power input. In the real world, there are always at least small losses for bearing friction and wire losses, etc., so the power output is always less than the power input.
For example, in my company's previous building, we used a motor/generator to convert 120Vrms @ 60Hz to 240Vrms @ 50Hz for testing the European versions of our products. The medium power motor/generator unit was about 4m^3 in volume, and made an impressive loud humming noise and was always pretty warm. Do you think that the fact that it made noise and was warm might detract from an ideal 100% efficiency? :smile:
I understand that but specifically for a homopolar generator what power is consumed by the rotor? An equation would be appreciated.
Nugatory
Mentor
12,952
5,644
There will be friction in the bearings, resistive heating from the current through the wire loop, and (if we aren’t enclosing the whole thing in a vacuum chamber) air resistance. The only one that will have a straightforward equation will be the resistive heating: ##P=I^2R## is the lost power.
Related Threads on Homopolar Motor Power
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
