1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Hooke's Law problem
  1. Jan 5, 2010 #1
    A mass of 1.0kg is attached to a spring obeying Hooke's Law F = k.s, where F is the force applied and s the spring extension. The spring constant, k is 50 N/m. The spring and the object lie on a surface tilted 45 degrees with respect to the vertical Neglect friction and answer the following questions:
    a. What is the extension of the spring?
    b. What is the work done by gravity in extending the spring by the above extension?
    2. Relevant equations
    F = k.s
    W = f.d
    3. The attempt at a solution
    1kg = 9.8N (force)
    Then resolve force into vert and horiz components= Tan45 x 9.8 = 9.8 (as tan45 is 1).
    Rearrange F = k.s into F/k = s
    9.8/50 = 0.196m = s
    Work done by gravity:
    9.8N x 0.196 = 1.92 Joules
    Does anyone know if this is right?
  3. Jan 5, 2010 #2
    This is wrong. Draw the right triangle representing the force and its components; the hypotenuse is the weight force (directed straight downward), so the components must be less than that.
  4. Jan 5, 2010 #3
    Where did you get tan45 from? The parallel component of the weight is 9.8*sin(45).
    No, because W=F*d only works if both F and d remain constant. F certainly does, but not d. Use the formula for potential energy instead: U=(1/2)kx^2. That's equal to the work done by gravity.
  5. Jan 5, 2010 #4
    Ahh yes that makes a lot more sense! Thanks for the help :)
    So I now make that:
    a) 0.139m
    b) 0.483 J
Similar Threads - Hooke's problem Date
Slide generator/hookes law problem Nov 7, 2017
Hooke's law and wave velocity related problem Jan 30, 2017
Young's Modulus problem Jan 28, 2017
