Hooke's Law/SHM Homework: Find Amplitude After Glue Breaks
In summary, a 1.50 kg ball and a 2.00 kg ball are attached to a vertical ideal spring and vibrating with an amplitude of 15.0 cm. When the glue connecting the balls breaks, the amplitude of the vibrations is 23.9 cm due to the minimum length of the spring. This is determined using the equations ΣF=ma, W=mg, and Fs=-kx, with values for the masses and force constant.
byu
A 1.50 kg ball and a 2.00 kg ball are glued together with the lighter
one below the heavier one. The upper ball is attached to a vertical ideal
spring of force constant 165 N/m and the system is vibrating vertically with
amplitude 15.0 cm. The glue connecting the balls is old and weak, and it
suddenly comes loose when the balls are at the lowest position in their
motion. Find the amplitude of the vibrations after the lower ball has come loose.
ΣF=ma
W=mg
Fs=-kx
m1=1.5kg
m2=2kg
∑F=ma
-kx1-(m1+m2)g=0
x1=(m1+m2)g/k
x1= .2079m
.15m+x1=.3579m
x2=(m2)g/k
x2=.11879m
.3579m - .11879m = .239m
Even after solving it, I do not really understand what is going on in the problem. Why is x=.2079 with both of them attached, when the amplitude is .15m?
x=.2079 is the displacement of the spring to the equilibrium point before the loosening. We are assuming in both cases that the masses vibrate about the equilibrium point.
So, it looks like this?
Yes.
Thing is; when x2 = 0.11879m its amplitude is 0.239m. Wouldn't that overshoot into the wall and affect its amplitude?
Good point but the assumption is that the spring has some minimum length, at least 0.208m. So your diagram should show this datum point and the wall offset that minimum amount.
1. What is Hooke's Law?
Hooke's Law is a principle in physics that describes the relationship between the force applied to an elastic material and the resulting deformation or change in length of the material. It states that the force applied is directly proportional to the displacement of the material.
2. What is Simple Harmonic Motion (SHM)?
Simple Harmonic Motion is a type of periodic motion where the restoring force is directly proportional to the displacement of the object from its equilibrium position. This type of motion can be seen in systems like a mass-spring system or a pendulum.
3. How do I find the amplitude after the glue breaks in a SHM problem?
To find the amplitude after the glue breaks in a SHM problem, you will need to use the equation A = x - d, where A is the new amplitude, x is the distance from the equilibrium point to the end of the spring, and d is the distance between the end of the spring and the point where the glue broke.
4. Can Hooke's Law be applied to all materials?
No, Hooke's Law can only be applied to materials that exhibit elastic behavior, meaning they can return to their original shape after being deformed by an applied force. Materials like rubber, metals, and plastics can generally follow Hooke's Law, but some materials like clay or putty do not.
5. How does the spring constant affect Hooke's Law and SHM?
The spring constant, represented by the letter k, is a measure of how stiff or elastic a spring is. In Hooke's Law, a higher spring constant means a stiffer spring, resulting in a greater force needed to deform the material. In SHM, a higher spring constant will result in a higher frequency and shorter period of oscillation.
