Horizontal Flame: Investigating an Unexplained Phenomenon
  • Thread starter NJV
  • Tags
    Horizontal
In summary, an incense stick with a small hole in the side can create a sideways jet of burning gas, which in turn can produce a horizontal flame.
NJV
39
I just lit a stick of incense. I observed that before the flame snuffed out, it consisted both of a vertical and a thinner horizontal flame. The horizontal flame was exactly perpendicular to the vertical one. It kept to a straight line and did not rise at all. Before I could photograph the flame, it went out.
I found this bizarre, since I have never seen or heard of a horizontal flame, nor could think of anything that could cause a flame to behave in such way. I'm curious what mechanism could explain this phenomenon.
A flame is just burning gas in air. The heat causes the burning matter to decompose forming the gases that burn.
So, what I think must've happened is that there was some cavity in the stick with a small hole in the side. The cavity filled up with combustion gases under pressure, which escaped through the hole and formed a sideways jet of burning gas. Voilá: A horizontal flame.
That sounds a likely explanation alxm.Why not try an experiment NJV by making a cavity?
Thanks for the quick and helpful reply, that sounds illuminating.
I'll try puncturing an incense stick with a needle and see what happens, but I'm not sure it will work. It's probably rather delicate.
I see horizontal flames coming out of jet engines all the time... :wink:
If alxm is right, it might actually be similar to that. :)
Were there any other factors that may have made the flame act the way it did?
I could only see a horizontal flame being produced if there is a force pushing the flame horizontally, such as what redargon said with jet engines. this cavity would have to go vertically from the top then would curve horizontally out the side. then a force, such as a slight push of air, would push the flame out the side. This could absolutely work; but with my luck, would fail completely.
1. What is a horizontal flame?
A horizontal flame is a phenomenon where a flame appears to burn parallel to the ground instead of in its usual upward direction.
2. What causes a horizontal flame?
The exact cause of a horizontal flame is still unknown, but it is believed to be caused by a combination of air currents, temperature differentials, and fuel source.
3. Is a horizontal flame dangerous?
In most cases, a horizontal flame is not dangerous as it is usually a small and controlled flame. However, it is always important to exercise caution and keep a safe distance from any flame.
4. Can a horizontal flame occur indoors?
Yes, a horizontal flame can occur indoors. However, it is more commonly seen outdoors due to the presence of natural air currents and open spaces.
5. How can we investigate a horizontal flame?
To investigate a horizontal flame, scientists use various techniques such as high-speed cameras, thermal imaging, and controlled experiments to study the phenomenon and gather data for analysis.
  • Materials and Chemical Engineering
  • Quantum Interpretations and Foundations
  • Classical Physics
