Horizontal Lift vs Parallel Transport in Principal Bundle & Riemannian Geometry
In summary: V_p(TU) where a^i...a_n \in [0,1] and X^i \in U. Note that (TU, (x^i, X^i)) is a coordinate system, but v is not. This is because v is not a vector in TS^2 , but it is a vector in TU .In summary, the horizontal lift of a curve in the base manifold of a principal bundle is related to the "classic" parallel transport of Riemannian geometry. One transports a given tangent vector of S2 as if it were in ℝ3 (
LargeDeviant
I am a physicist trying to understand the notion of holonomy in principal bundles.
I am reading about the horizontal lift of a curve in the base manifold of a principal bundle (or just fiber bundle) to the total space and would like to relate it to the "classic" parallel transport one comes across in Riemannian geometry. (I am guessing that the horizontal lift picture of the fiber bundle must be a generalization of the "classic" parallel transport of Riemannian geometry).
In particular, I would like to consider the example of parallel transporting a tangent vector (v) of S2 (embedded in ℝ3) in terms of horizontal lift. The picture I have for the "classic" parallel transport (in tangent bundle) is that one transports (infinitesimally) a given tangent vector of S2 as if it were in ℝ3 (Tℝ3) and then projects it back to the tangent space of S2.
To extend this picture in terms of the horizontal lift, I am considering the total space E as TS2, base manifold B as S2 and the fiber Ex at x as TxS2. The projection map then is clearly [itex]\pi[/itex]: TS2 [itex]\rightarrow[/itex] S2: (x,v) [itex]\rightarrow[/itex] x. However, when trying to find the vertical space of the TxE, I am getting confused about d[itex]\pi[/itex]:T(TS2)[itex]\rightarrow[/itex]TS2. How do I make sense of T(TS2) in order to find ker(d[itex]\pi[/itex])?
I am not even sure how, with this approach, after completing a loop one will "move along the fiber"? And how does one eventually relate all this to the picture of moving the vector in ℝ3 and projecting back to tangent space of S2.
Any help would be greatly appreciated. Thank you!
I may be able to provide a little help:
Trying to determine what [itex] T(TS^2) [/itex] looks like geometrically may be a little tough. Perhaps there is somebody out there with better geometric insight than myself, but I find it best to abstract away the internal [itex] TS^2 [/itex] part. To be more precise, if we set [itex] M = TS^2 [/itex] then [itex] T(TS^2) = TM [/itex] is just the tangent bundle of this new manifold [itex] M [/itex]. This is in a sense "cheating," but maybe we can do a bit better.
I do not know about you, but one of the many ways I visualize [itex] T_p M [/itex] is as the collection of tangent vectors to M at the point p. In fact, if [itex] \tilde V \in T_p M [/itex] is a tangent vector, we may identify it with [itex] \tilde V = (p,v) [/itex] for [itex] p \in M [/itex] and [itex] v \in T_p M [/itex] is an "arrow." Hence an element of [itex] \tilde V \in T_p (TS^2) [/itex] looks like (p,v), where [itex] p \in TS^2 [/itex] and v is an arrow at the point p. But we can break this down even further, and realize that p will look like [itex] p = (x,w) [/itex] for some [itex] x \in S^2 [/itex] and [itex] w \in T_x S^2 [/itex]. In a sense, we may then think of elements in [itex] T(TS^2) [/itex] as triples (x,w,v).
You may already know this part, but let me re-iterate as it will be useful for the next part. For arbitrary manifolds M and N, and [itex] f: M \to N [/itex] a smooth map, we think of the pushforward/differential of f at p, [itex] d_p f : T_p M \to T_{f(p)}N [/itex] as the map which takes tangent vectors at p in M to tangent vectors at f(p) in N. At this point, I find the best way to think about how this map behaves is by defining tangent vectors as the differential of a smooth curve on M. If [itex] \gamma:[0,1] \to M [/itex] is a smooth curve with [itex] \gamma(0) = p, \gamma'(0) = v \in T_p M [/itex] then [itex] f_* v [/itex] is essentially [itex] (f\circ \gamma)'(0) [/itex]; that is, we look at the image of the curve under f, and differentiate at zero.
Back to your question: how then do we compute [itex] \ker d \pi [/itex]? We can intuitively guess what is happening using the previous paragraph. The projection map takes curves in [itex] TS^2 [/itex] to curves in [itex] S^2 [/itex] by just projecting onto the basepoint. In essence, it completely forgets about the tangent vectors themselves. Thus we expect that [itex] d\pi [/itex] will do something similar.
To see that this is true, it may be best to work with a coordinate system. Let [itex] (U,x^i ) [/itex] be a coordinate chart on an arbitrary manifold M of dimension n. We know there is then an induced coordinate system on [itex] TU [/itex], which we shall write as [itex] (TU, (x^i, X^i)) [/itex]. Now every element of [itex] v\in T_p(TU) [/itex] may be written as
[tex] v = \sum_{i=1}^n \left[ a^i \left. \frac{\partial}{\partial x^i}\right|_{p} + b^i \left. \frac{\partial}{\partial X^i} \right|_p \right]. [/tex]
Since the differential is linear, we then have
[tex] (d_p \pi)v = \sum_{i=}^n \left[ a^i \left. d_p\pi\frac{\partial}{\partial x^i}\right|_{p} + b^i d_p\pi\left. \frac{\partial}{\partial X^i} \right|_p \right] [/tex]
so it suffices to determine how [itex] d_p \pi [/itex] acts on the basis vectors [itex] \frac\partial{\partial x^i}, \frac\partial{\partial X^i} [/itex]. If [itex]\frac\partial{\partial y^i}, \frac\partial{\partial Y^i} [/itex] is a basis for [itex] T_{\pi(p)}(TU) [/itex] then the standard change of basis formula tells us that
[tex] d_p\pi \left. \frac\partial{\partial x^i } \right|_p = \sum_{j=1}^n \left[\frac{\partial \pi^j}{\partial x^i}(p) \left. \frac{\partial}{\partial y^i} \right|_p + \frac{\partial \pi^j}{\partial X^i}(p) \left. \frac{\partial}{\partial Y^i} \right|_p \right][/tex]
and similarly for the [itex] X^i [/itex] and [itex] Y^i [/itex]. This just says that the pushforward is precisely the Jacobian! Now computation of [itex] d_p \pi [/itex] is simple since we know exactly what [itex] \pi [/itex] does in coordinate. Namely, [itex] \pi (p, w) = p [/itex] so that
[tex] \frac{\partial\pi^j}{\partial x^i} = \delta^j_i, \qquad \frac{\partial \pi^j}{\partial X^i} = 0. [/tex]
In block diagonal form, the coordinate representation is thus
[tex] d_p\pi = \begin{pmatrix} I_n & 0 \\ 0 & 0 \end{pmatrix}. [/tex]
In the language of our triples, the differential of the projection thus takes vectors (x,w,v) to the vector (x,w): it forgets about the tangent vectors, exactly as we would expect!
This has become rather long-winded, so I will leave the my remaining comments as a reference. Namely, to see how horizontal lifts and parallel transport relate on general connects, take a look at Salamon's notes on differential topology. The information you are looking for is contained in Chapter 10.
Thanks Kreizhn!
The triple (x,w,v) and the differential [ itex ] d \pi: (x,w,v) \rightarrow (x,w) [/ itex ] that you mention certainly makes sense (with v being 2 dimensional in order to keep the [ itex ] dim(T(TM)) = 2 dim(TM)[ / itex ]).
Thanks for pointing me to Salamon's notes. They seem very useful and I do hope I can find what I am looking for there.
For now, I have a feeling that to reconcile the horizontal lift picture of fiber bundle to the parallel transport of Riemannian geometry, we need to embed [ itex ] T(TS^2) [/ itex ] in ℝ3 and somehow the vertical space of [ itex ] T(TS^2) [/ itex ] must become normal to [ itex ] TS^2 [/ itex ] while the horizontal space can be chosen to be [ itex ] TS^2 [/ itex ] (which will be perpendicular to the vertical space due to the induced metric from ℝ3). I will have to think a bit more about it but thanks again for your help.
The parallel translate of a frame around a closed curve is another - possibly different - frame. The linear map that changes the frames is an element of the holonomy group.
For orientable surfaces, the bundle of orthonormal frames is just the tangent unit circle bundle. A unit vector field maps a curve into this bundle and its derivative at a point lies in the tangent space to the unit circle bundle. The vector field is parallel at the point if the projection of the derivative onto the fiber - using the connection 1 form - is zero.
The pull back of the connection one form - using the vector field - gives you the covariant derivative (with a little algebra).
the orthogonal projection of a covariant derivative is a covariant derivative. This is a simple calculation. A vector field is parallel if its tendency to turn along the curve is orthogonal to the hypersurface. So for instance, a unit speed geodesic is just a curve whose acceleration is normal to the submanifold.
The tangent unit circle bundle of the 2 sphere is diffeomorphic to the projective space of lines in real 3 space.
A good exercise to see how this all works on the sphere is to construct its connection 1 form.
Hello, as a scientist with a background in mathematics, I can provide some clarification on the concepts of horizontal lift and parallel transport in principal bundle and Riemannian geometry.
Firstly, the horizontal lift of a curve in the base manifold of a principal bundle is a way to lift the curve to the total space of the bundle while preserving its tangent direction. This is different from the "classic" parallel transport in Riemannian geometry, which involves transporting a tangent vector along a curve while keeping it tangent to the surface at every point.
The horizontal lift can be thought of as a generalization of parallel transport, as it also preserves the tangent direction of the curve, but it allows for more flexibility in the choice of curve and the total space of the bundle.
In the example you mentioned, the total space E is indeed the tangent bundle of S2, and the base manifold B is S2 itself. The fiber at a point x in S2 is the tangent space TxS2, and the projection map \pi: TS2 \rightarrow S2 sends a tangent vector at x to the point x.
Now, to find the vertical space of the tangent space TxE, we need to consider the tangent space of the tangent space, which is denoted as T(TS2). This is the space of all tangent vectors to the tangent bundle at a given point. The map d\pi:T(TS2)\rightarrow TS2 can then be understood as the derivative of the projection map at each point, which tells us how the tangent space at one point is related to the tangent space at another point.
To understand how this relates to the picture of moving a vector in ℝ3 and projecting it back to the tangent space of S2, we can think of the tangent bundle TS2 as a way to "embed" S2 in ℝ3. The tangent space at each point x in S2 is then the tangent plane to S2 at that point, and the projection map \pi sends a tangent vector at x to the point x on the surface.
In terms of completing a loop and "moving along the fiber," this relates to the concept of holonomy in principal bundles. Holonomy is a way to measure how a vector changes after it is transported along a closed curve in the base manifold. In the case of parallel transport in Riemannian geometry, the holonomy is trivial, meaning that the vector returns to its original state
1. What is the difference between horizontal lift and parallel transport?
Horizontal lift and parallel transport are two methods used in Principal Bundle and Riemannian Geometry to move a vector or tensor along a path on a manifold. The main difference between these two methods is that horizontal lift preserves the horizontal component of the vector or tensor, while parallel transport preserves the direction of the vector or tensor.
2. When is it appropriate to use horizontal lift over parallel transport?
Horizontal lift is commonly used when dealing with principal bundles, which are fiber bundles with a group structure. It is also useful when working with connections, as it preserves the horizontal component of the connection. Therefore, horizontal lift is often used when dealing with Lie groups and their associated bundles.
3. How does horizontal lift relate to the horizontal space of a principal bundle?
The horizontal space of a principal bundle is the subspace of the tangent space at each point that is orthogonal to the vertical space. Horizontal lift is a method that moves a vector or tensor along the horizontal space of a principal bundle, resulting in a new vector or tensor that is still in the horizontal space.
4. Can vertical components of a vector or tensor be affected by horizontal lift?
No, horizontal lift only affects the horizontal component of a vector or tensor. The vertical component, which is in the direction of the fibers of the bundle, remains unchanged.
5. How does parallel transport differ in Euclidean vs Riemannian Geometry?
In Euclidean Geometry, parallel transport preserves both the direction and magnitude of a vector or tensor, while in Riemannian Geometry, it only preserves the direction. This is because the metric tensor in Riemannian Geometry introduces curvature, which affects the magnitude of the vector or tensor as it is transported along a path.
  • Differential Geometry
