Horizontal Tangent Line
In summary: ?in summary, the homework statement is that you need to find the slope of a horizontal line when you do not have a certain point.
nejnadusho
31
Find all points on the graph of the function at which the tangent line is horizontal.
f(x) = 2sinx + (sinx)^2
Hi guys I have an issue. I do not know how to approach this problem.
I know the chain rule but I still do not know how to solve the prolem.
Thank you for your help.
the tangent line is the slope of f(x) at some point, how do you find that slope?
The derivative of the function gives you the slope of the tangent line at each point x.
How do you know when a line is horizontal?
Now, how can you find which points have horizontal lines?
what is the slope of a horizontal line?
slope is always rise over run; if its instantaneous then its derivative of rise of derivative of run.
if its an entire straight line, the slope is rise over run. So, what's the rise per unit of run?
nejnadusho, the ball is back in your court! Everyone is asking you the same question: what is the slope of a horizontal line?
Ok
I am sorry there was something wrong and I could not open the page yestarday.
I guess I should find the derivative of the f(x) which means I should find f'(x) and after
the equation of the tangent line . right?
And i guess the slope is horizontal when the f(x) of the slope equals ohhh no.
When x of the function of the slpope is 0(zero) right?
nejnadusho said:
Ok
I hope that means 'when f'(x)=0'.
Actually
I got lost again because I found the derivative
but How am I suppose to find the equation of the tangent line when I do not have a certain point.
Do I need it actually?
I mean some point?
So if I substitute x by 0 I am going to find the point where the slope of the tangent line is 0 ?
nejnadusho said:
Actually
I mean some point?
It doesn't ask you for the equation of the tangent line. It's asks you for what values of x and y does the tangent line have zero slope. Start by finding the x values.
Tell us what you got for f'(x). Write the equation f'(x)=0. Now try to solve for x.
But I am going to find only one y for each x so how am I suppose to find more than one zero slope if there is?
If you 'substitute x by 0' you are going to find the slope of the tangent line at x=0. You want to know where the slope is zero. Tell us what you got for f'(x). Write the equation f'(x)=0. Now try to solve for x.
ok
f'(x)= 2cos x (sin x + 1)
2cos x (sin x + 1) = 0
ok but how am I suppose to solve it for x now?
nejnadusho said:
ok
Good! You've even factored it. If the product of those factors is 0, then either cos(x)=0 OR (sin(x)+1)=0. For what values of x is cos(x)=0?
Pi/2 for cosx
and ((3*Pi)/2) for sin
I am dum
I stay I am doing something and I cannot realize that I just solve the problem.
Good so far, but the problems asks for ALL points. E.g. cos(3pi/2)=0, cos(5pi/2)=0, etc. etc. And sin(-pi/2)=(-1) and sin(7pi/2)=(-1). Can you clearly describe all of them? Once you've done that, you just need to get the corresponding y values.
Thank you very much for the way you helped me.
Thank you very much guys.
Yes but isn't the coresponding values of y allways the same?
are not they always y= 0 for cos and y = -1 for sin ?
I mean for this problem.?
To get the y values you have to put the x values into f(x) = 2sinx + (sinx)^2, not the derivative, right?
ohhh really?
sooo
for f((3*Pi)/2) = -1
and
f(Pi/2) = 3
but why all
that
why I take the values from the derivative and substitute them in the original equation?
so are not these values actually the domain of the original function?
nejnadusho said:
ohhh really?
sooo
and
f(Pi/2) = 3
but why all
that
Because you problem asked you to "Find all points on the graph" and points have both x and y values. Solving f '(x)= 0 gives you the x values where the tangent is 0 but you still need the corresponding y values.
its just like solving for the zero's (x-intercepts) of any polynomial equation.
how can you get 2cosx*(sinx + 1) to = 0. either cosx = 0 or sinx + 1 = 0. what values of x give you those? and here we see the 2 solutions (actually infinite solutions, but for practical purposes, 2)
What is a horizontal tangent line?
A horizontal tangent line is a line that is parallel to the x-axis and touches a curve at a single point, with the slope of the curve at that point being 0.
How do you find the equation of a horizontal tangent line?
To find the equation of a horizontal tangent line, you need to first find the derivative of the curve. Then, set the derivative equal to 0 and solve for the x-value. This x-value will give you the x-coordinate of the point where the horizontal tangent line touches the curve. Substitute this x-value into the original equation of the curve to find the corresponding y-value. The equation of the horizontal tangent line will be y = (corresponding y-value).
What is the significance of a horizontal tangent line?
A horizontal tangent line indicates that the slope of the curve at that point is 0, which means that the curve is neither increasing nor decreasing at that point. This can be useful in determining the maximum or minimum points of a curve.
Can a curve have more than one horizontal tangent line?
No, a curve can have at most one horizontal tangent line at a given point. This is because a horizontal line can only intersect a curve at one point, and the slope of the curve at that point must be 0.
How can knowing about horizontal tangent lines be applied in real life?
Horizontal tangent lines can be used to analyze the rate of change of a quantity, such as speed or acceleration. For example, a horizontal tangent line on a velocity-time graph would indicate a constant velocity, while a horizontal tangent line on an acceleration-time graph would indicate a constant acceleration. This can be helpful in understanding the behavior of objects in motion.
