1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
How big should asteroids be to
  1. Nov 8, 2009 #1
    Consider main-belt chondritic asteroids. How large should be an asteroid so that the
    maximal internal temperature exceeds the melting temperature of ice? Of rocks? For your
    calculations, use the present-day chondritic heat production w = 4×10-12 W kg-1, typical
    thermal conductivity of slightly fractured rock k = 2 W K-1m-1, and density r = 2700 kg
    m-3 representative of chondritic materials. Make (and explain) a reasonable guess about
    the surface temperature Ts and melting temperatures Tm of ice and rocks
  3. Nov 8, 2009 #2
    mgb_phys
    Welcome to PF - you have to show some attempt to work out the homework before we can help.
  4. Nov 8, 2009 #3
    well i know heat flux = -k(dt/dr) this is change in temperature with depth and thermal diffusivity x= k/pC (here p is density and C is heat capacity). I just don't know how to apply heat production. I feel like i'm missing an equation and i have no idea what it is.
  5. Nov 8, 2009 #4
    mgb_phys
    Heat production is given per mass, so with the density it's easy to work out heat production/volume. If you assume a spherical asteroid you can get a heat prouction / radius relation
  6. Nov 8, 2009 #5
    the units for that would be W/m^3. this is almost heat flux (W/m^2). where would i go from there?
  7. Nov 9, 2009 #6
    asteroid size
    How large should be the body so that the maximal internal temperature reaches given
    temperature Tm (melting temperature)?
    I'm thinking i can use F= K*[(Ta-Tb)/(Ra-Rb)]. where F is heat flux, K is thermal conductivity, T is change in temperature and R is change in depth.
    I'm thinking the radius i need should be R=(K*(Tm))/F, but i'm not sure if it is that easy.
    I need some reassurance.
    Thank you
  8. Nov 9, 2009 #7
    berkeman
    Staff: Mentor
    (two threads on the same question merged into one)
    (thread moved to Advanced Physics Homework Help)
Similar Discussions: How big should asteroids be to
  1. Asteroids momentum (Replies: 1)
  2. Asteroid problem (Replies: 0)
  3. Asteroids momentum (Replies: 1)
Loading...
