How can Helium 4 be a Boson and Helium 3 be a Fermion?
In summary, the spin of composite particles, such as He-4 atoms, is determined by the spin of their constituent particles. He-4 is considered a boson because it has an integer spin of 0, while He-3 is considered a fermion because it has a half spin of 1/2. This is due to the way the individual spins of the particles are coupled in the composite system. Additionally, the statistics that particles follow also play a role in determining whether they are fermions or bosons. Both He-3 and He-4 can occupy the same space at the same time, but only in certain conditions, such as in Bose-Einstein condensates.
Calcifur
24
Hi there,
Just a quick question which I'm sure I'm over complicating in my head.:confused:
I've read that Helium 4 is a Boson because it has 0 spin and that Helium 3 is a Fermion because it has 1/2 spin. Is this right? I don't see how whole atoms can be associated with fundamental particle groups.
Why do each have those particular spins and why does that constitute them to be either Fermion or a Boson.
Also one other thing: Is it "integer spin" or "integral spin"? Do they mean the same thing because I keep seeing them being interchanged when talking about Fermions and Bosons?
Many thanks in advance for your help. :biggrin:
In order to associate a spin to a composite system one has to couple the individual spins (and orbital angular momenta); in the case of He-n one couples n nucleons and n electrons. Assuming that higher spin i.e. higher angular momentum is associated with higher energy, the ground state of such a system is always the state with lowest angular momentum.
Lowest total spin for n=4 i.e. 8 fermions is S=0, lowest total spin for n=3 i.e. 6 fermions is S=1/2.
Hi Tom,
Thanks for your response but I think I need the response in simpler terms. So are you saying that due to He 3 lacking a neutron its total spin cannot cancel to zero?
Is it just a fundamental definition that Fermions have half spin and Boson's have integer spin?
And does that mean that ANY atom can be either a Fermion or a Boson depending on its resultant total spin?
I only say this because I always assumed that F's and B's were fundamental particles.(i.e. NOT associated with atoms but more their components.)
Furthermore I've also read that 2 Bosons can occupy the same space but Fermions cannot. Does this mean that two He 4 atoms can be in the same place at the same time?
Right.
The fundamental definition is the statistics they follow, but for all known particles (and in 3 spatial dimensions), the spin value can be used as definition, too.
Right, and it has to be one of those. You can even see this with Rubidium (with >100 components) at Bose-Einstein condensation, for example.
This happens in Bose-Einstein condensates.
By the way: Protons and neutrons are not elementary particles either, and they have a well-defined spin of 1/2.
Hi mfb,
Thank you so much for answering each question individually. You have really helped me to get things straight in my head so I really appreciate it!
Calcifur
Calcifur said:
Hi there,
Actually, there are two different and inequivalent definitions of, say, bosons. On the one hand, they are often defined as particles with integer spin, on the other hand, sometimes they are defined as particles for which only symmetric states exist in nature (see, e.g., Dirac's "Principles of Quantum Mechanics"). Composite particles, such as He 4 atoms, can be bosons under the first definition, but not under the second one.The commutation relations for operators of creation/annihilation of He 4 atoms are derived from the anticommutation relations for the operators of creation/annihilation of protons, neutrons, and electrons that are parts of the atoms (and an even more precise treatment would require starting with quarks for neutrons and protons), and those commutation relations approximately coincide with the commutation relations for boson creation/annihilation operators in the limit of low density. Please see the details (for the example of deuterons) in the book by Lipkin called "Quantum Mechanics. New Approaches to Selected Topics".
Hi akhmeteli,
Thank you for your response. I think its safe to assume that the text I was reading was referring to the first definition for Bosons then. Thanks for your references too. I will investigate further.
Without access to Lipkin's book, I'm wondering if the discussion in this paper on the commutation relations obeyed by "quasibosons" is equivalent. They do have a reference to Lipkin. (Just skip over the paper's speculative parts!)
Looks similar
so are you saying that he-4 atoms can occupy the same space at the same time?
I don't know if you're asking me, but the commutation relations for He 4 creation/annihilation operators, strictly speaking, differ from the canonical commutation relations for boson operators, so you cannot place an unlimited number of limited energy He 4 atoms in a limited space due to the Pauli principle for the constituent particles of He 4 atoms.
What is the difference between a Boson and a Fermion?
A boson is a particle that follows Bose-Einstein statistics and has integer spin, while a fermion follows Fermi-Dirac statistics and has half-integer spin.
Why is Helium 4 considered a Boson?
Helium 4 has an even number of protons, neutrons, and electrons, which results in an integer spin of 0. This makes it a boson according to the spin-statistics theorem.
How does the spin of Helium 4 affect its behavior as a Boson?
The integer spin of Helium 4 allows multiple particles to occupy the same quantum state, leading to phenomena such as Bose-Einstein condensation.
Why is Helium 3 considered a Fermion?
Unlike Helium 4, Helium 3 has an odd number of particles, resulting in a half-integer spin of 1/2. This makes it a fermion according to the spin-statistics theorem.
What are the implications of Helium 3 being a Fermion?
As a fermion, Helium 3 cannot occupy the same quantum state as another particle, leading to different properties and behavior compared to Helium 4. This makes Helium 3 useful for studying quantum mechanics and superfluidity.
  • High Energy, Nuclear, Particle Physics
  • Beyond the Standard Models
  • Atomic and Condensed Matter
