Simplifying Transmission Coefficient Calculation for a Potential Barrier
  • Thread starter Nylex
  • Tags
    Simplify
In summary, the transmission coefficient T for a potential barrier between x = 0 and x = a is equal to: 4k_1k_2\cosh(k_2a)+2i(k_2^2-k_1^2)\sinh(k_2a)
Nylex
552
Hi, I've been doing a QM problem to do with a potential barrier going from x = 0 to x = a. I need to work out an expression for the transmission coefficient T and have a horrible looking expression:
I can't use LaTeX properly, so:
A = (F/4k_{1}k_{2}).e^ik_{1}a[e^-k_{2}a (k_{2} + ik_{1})(k_{1} - ik_{2}) + e^k_{2}a (k_{2} - ik_{1})(k_{1} + ik_{2})]
where k_{1} = (1/hbar)(2mE)^1/2, k_{2} = (1/hbar)[2m(V_{0} - E)]^1/2
How on Earth do I simplify this further? Thanks.
Is this what u meant...?
[tex] A = (F/4k_{1}k_{2})\cdot e^{ik_{1}a}[e^{-k_{2}a} (k_{2} + ik_{1})(k_{1} - ik_{2}) + e^{k_{2}a} (k_{2} - ik_{1})(k_{1} + ik_{2})] [/tex]
,where [tex]k_{1} = (1/\hbar)(2mE)^{1/2}, k_{2} = (1/\hbar)[2m(V_{0} - E)]^{1/2} [/tex]
Daniel.
P.S.Won't u be needing the square modulus of this expression?
Yikes. I've done this problem before. I know it's not pretty.
Anyway, if you work out the brackets:
[tex]e^{-k_2a}(k_{2} + ik_{1})(k_{1} - ik_{2})[/tex]
and
[tex]e^{k_2a}(k_{2} - ik_{1})(k_{1} + ik_{2})][/tex]
you can rewrite the sum as:
[tex]2k_1k_2\left(e^{k_2a}+e^{-k_2a}\right)+i(k_2^2-k_1^2)(e^{k_2a}-e^{k_2a})[/tex]
The exponential combinations form hyperbolic sinusoids. The expression is equal to:
[tex]4k_1k_2\cosh(k_2a)+2i(k_2^2-k_1^2)\sinh(k_2a)[/tex]
So the original expression becomes (divide both sides by F, since you're interested in T=|F/A|^2, right?):
[tex]\frac{A}{F}=e^{ik_1a}\left(\cosh(k_2a)-\frac{i}{2}\left(\frac{k_2^2-k_1^2}{k_1k_2}\right)\sinh(k_2a)\right)[/tex]
Take the modulus squared on both sides (the term in brackets is in the form a+bi with a and b real, so it's simply a^2+b^2):
[tex]T^{-1}=\frac{|A|^2}{|F|^2}=\cosh^2(k_2a)+\frac{1}{4}\left(\frac{k_2^2-k_1^2}{k_1k_2}\right)^2\sinh^2(k_2a)[/tex]
Now use the expressions for [itex]k_1, k_2[/itex] to show that:
[tex]\left(\frac{k_2^2-k_1^2}{k_1k_2}\right)^2=-4+\frac{V_0^2}{E(V_0-E)}[/tex]
Use the identity [itex]cosh^2(x)-sinh^2(x)=1[/itex] and write out [itex]k_2[/itex] in the argument to get the final answer.
..whew
Ahh, cheers both of you.
1. How do I simplify equations?
To simplify an equation, you can follow these steps:
1. Combine like terms
2. Use the distributive property to remove parentheses
3. Simplify exponents
4. Combine any remaining terms
5. Check your answer by plugging in values for the variables.
2. Can you give an example of simplifying an expression?
Sure! Let's say you have the expression 3x + 5 + 2x - 4x. First, we combine like terms to get 3x + 2x - 4x + 5. Then, we simplify to get x + 5.
3. How do I simplify fractions?
To simplify a fraction, you can follow these steps:
1. Find the greatest common factor (GCF) of the numerator and denominator
2. Divide both the numerator and denominator by the GCF
3. Simplify any remaining fractions
4. Check your answer by plugging in values for the variables.
4. What is the difference between simplifying and solving?
Simplifying is the process of rewriting an expression into its simplest form, while solving is the process of finding the value of a variable in an equation or inequality. Simplifying often involves combining like terms and simplifying fractions, while solving involves using algebraic methods to isolate the variable on one side of the equation or inequality.
5. Is there a specific order to simplify expressions?
Yes, there is a specific order to simplify expressions, known as the order of operations. The order is as follows:
1. Parentheses
2. Exponents
3. Multiplication and Division (from left to right)
4. Addition and Subtraction (from left to right)
It is important to follow this order to ensure that you get the correct answer.
  • Quantum Physics
