How can I simplify 1-2*sqrt(x)*sin(sqrt(x))*cos(sqrt(x))?
  • Thread starter Math10
  • Tags
    Simplify
In summary, the conversation discusses how to simplify the expression 1-2*sqrt(x)*sin(sqrt(x))*cos(sqrt(x)) by using the identity sin(2x)=2sin(x)cos(x). It is suggested to let A = sqrt(x) and then replace A in the expression to get 1-sqrt(x)*sin(2*sqrt(x)).
Math10
301
How to simplify 1-2*sqrt(x)*sin(sqrt(x))*cos(sqrt(x))?
None.
I know the identity that sin(2x)=2sin(x)cos(x).
None.
Or sin(2A) = 2sin(A)cos(A).
Let A = ##\sqrt{x}##. Can you do something with that?
So it's 1-Asin(2A)?
Math10 said:
So it's 1-Asin(2A)?
You tell us.
1-Asin(2A).
Math10 said:
1-Asin(2A).
But what is A? There is no A in the original problem.
You said to let A=sqrt(x). See what you posted above.
Right. So now replace A by ##\sqrt{x}##.
So 1-sqrt(x)*sin(2*sqrt(x)).
It's easy enough to check whether this is equal to what you started with.
LOL, never mind. I found my mistake in the problem. Thanks for the help.
1. How do I simplify an equation?
To simplify an equation, you need to combine like terms, use the distributive property, and follow the order of operations. This will help you to get rid of any unnecessary terms and make the equation easier to solve.
2. Can I simplify an expression with variables?
Yes, you can simplify expressions with variables by grouping like terms, combining coefficients, and using the properties of exponents. The goal is to get the expression in its simplest form, with no more than one variable term.
3. What are some common mistakes to avoid when simplifying?
One common mistake to avoid is forgetting to distribute negative signs or coefficients when using the distributive property. Another mistake is not following the correct order of operations, which can change the answer. It is also important to double-check your answer by plugging it back into the original equation.
4. How do I know when an expression is fully simplified?
An expression is fully simplified when all like terms are combined, there are no parentheses left to distribute, and the coefficients are as small as possible. The variables should also be in alphabetical order, and there should be no more than one variable term.
5. Is there a shortcut to simplifying expressions?
Yes, there are certain rules and properties that you can use to simplify expressions faster. For example, the commutative and associative properties allow you to rearrange terms and group them in different ways without changing the answer. It is important to learn and understand these rules to simplify expressions efficiently.
