How do I find the limit of a geometric sequence?
  • Thread starter d125q
  • Tags
    Limit
In summary, the limit is to be solved by multiplying the first two together and it is equivalent to summing 1/2^n.
d125q
The following limit is to be solved:
\lim_{n\to\infty}(\sqrt{2} \cdot \sqrt[4]{2} \cdot \sqrt[8]{2} \cdot \sqrt[16]{2} \cdot … \cdot \sqrt[2^n]{2})
all of my attempts to (properly) solve it so far have been futile.
And help will be greatly appreciated!
EDIT: Perhaps this should go to precalc? It's the first time I'm posting here-- so please go easy on me.
and I am absolutely clueless about coming up with a solution.
First, I would rewrite this with the pi operator to clean things up:
[tex]\prod\limits_{n=1}^{\infty} 2^{\frac{1}{2^n}}[/tex]
Let's see when you multiply the first two together:
[tex]2^{1/2}*2^1/4=2^{1/2+1/4}[/tex]
If you multiply the next one:
[tex]2^{1/2+1/4}*2^{1/8}=2^{1/2+1/4+1/8}[/tex]
As you can see, this:
Is equivalent to:
[tex]\sum_{n=1}^\infty 2^{1/2^n}[/tex]
See where this goes?
Is equivalent to:
If logic serves me well, 1 / 2^n approaches zero, so the whole product equals 1. Is that right (sorry, but I'm rather dizzy right now)?
Thanks a million!
Is equivalent to:
No: it is equivalent to
[tex] 2^{\sum_{n=1}^{\infty} 1/2^n}.[/tex]
RGV
RGV
Indeed. I am still in high school, so we kind of shun the sigma and pi operators, but they surely make the whole deal a lot easier.
So, does my above post stand?
Parts of it stand, yes, but your final expression is incorrect, as I have plainly indicated. Your sum is infinite, but the correct answer is finite (and not very large).
RGV
Oh, damn. I must be blind. So,
[tex]\sum_{n=1}^{\infty} \frac{1}{2^n} = \frac{\frac{1}{2}}{1 - \frac{1}{2}} = 1[/tex]
in which case,
[tex]2^{\sum_{n=1}^{\infty} \frac{1}{2^n}} = 2[/tex]
You're awesome, guys.
RGV
Nice catch, my bad.
I'm a sophomore in high school :p
What is a limit?
A limit is a fundamental concept in calculus that represents the value that a function approaches as its input approaches a particular value.
What are the different types of limits?
The three types of limits are one-sided limits, where the function approaches the input from one side only, two-sided limits, where the function approaches the input from both sides, and infinite limits, where the function approaches either positive or negative infinity.
How do I evaluate a limit algebraically?
To evaluate a limit algebraically, you can use techniques such as factoring, rationalizing the numerator or denominator, and simplifying the expression. If the limit is indeterminate, you can use L'Hospital's rule or other advanced techniques.
How do I determine if a limit exists?
A limit exists if the function approaches the same value regardless of which direction you approach the input from. You can also determine if a limit exists by evaluating the limit algebraically and checking if the result is a real number.
What are some common techniques for solving limits?
Some common techniques for solving limits include direct substitution, factoring, rationalizing the numerator or denominator, and using trigonometric identities. Advanced techniques such as L'Hospital's rule, squeeze theorem, and limit laws can also be used for more complex limits.
