• Support PF! Buy your school textbooks, materials and every day products via PF Here!
How do you change the magnitude of a vector?
  • Thread starter omicron
Three vectors a, b and c are such that a = i + 3j, b = 2i + j and c = i + 13j. Find
(i) the vector which is parallel to a + b and of magnitude 20 units.
(ii) the value of p and of q for which pa + qb = c
I need help in both parts.
1,062
i)
what is a+b ?
Then, what is the definition of a unit vector? And then how do you change the magnitude of a vector?
ii) What does pa mean, and qb mean? You will have two equations. One will solve the c i component, the other will solve the c j component.
what is the magnitude of a + b?
you need a vector of maginutude 20, in the same direction of a + b.
the scale of your magnitudes should be the same as the scale of your components. (check it for yourself - can you see it's just similar triangles?)
look out for this nice 3,4,5 triangle; they can simplify calculations if you spot them.
i.e where two sides are of length 3 and 4 units, while the hypotenuse is 5 units. that is, if you have a triangle with two of the sides being any two of these numbers, you know immediately the other side must be the missing number.
5,12,13 is another one to look out for. a bit trickier to spot.
These pop up frequently!
Thank you.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
