What is the maximum height water can rise in xylem channels due to capillarity?
  • Thread starter caamb
  • Tags
    Density
In summary, water is transported upwards in plants through xylem tissue, which is made up of cells that are 1 mm in length and have a diameter of 335 µm. These xylem cells are connected to each other to form a channel. The maximum height that water can rise in these xylem channels due to capillarity can be calculated using the equation hmax = 2δ/(density)(g)(r), where δ is 0.073, r is 3.335 x 10^-6 / 2, and the density of water can be easily found in physics textbooks or online.
caamb
Water is transported upward in a plant through xylem tissue, which consists of cells of 1 mm length and a diameter of 335 µm. The xylem cells are attached to each other to form a channel. To what maximum height can water rise in these xylem channels due to capillarity?
How do you do this problem with the lack of information? How do you find density?
hmax=2δ/(density)(g)(r)
δ=0.073
r=3.335X10-6 / 2
The density of water? That's a pretty standard number which can be found in most physics textbooks. It can even be found on the internet. I heard that the density of water is even a standard in the metric system.
1. What is density?
Density is a physical property that measures the amount of mass in a given volume of a substance. It is typically represented by the symbol "ρ" and is calculated by dividing the mass of a substance by its volume.
2. How do you find the density of a solid?
To find the density of a solid, you need to measure its mass using a scale and its volume using a ruler or displacement method. Then, divide the mass by the volume to get the density. The units for density are typically grams per cubic centimeter (g/cm3) for solids.
3. How do you find the density of a liquid?
The density of a liquid can be found by using a graduated cylinder to measure its volume and a scale to measure its mass. Then, divide the mass by the volume to get the density. The units for density of liquids are typically grams per milliliter (g/mL) or grams per cubic centimeter (g/cm3).
4. Why is density an important property?
Density is an important property because it allows us to identify and classify substances. It also helps us understand how different substances will behave in various situations, such as when they are heated or cooled. Additionally, density is used in many practical applications, such as determining the purity of a substance or calculating the buoyancy of an object.
5. Can density change?
Yes, density can change. It can vary depending on the temperature, pressure, and other external factors. For example, when a gas is compressed, its density increases. Additionally, substances can change states (solid, liquid, gas) which can also affect their density. However, the density of a pure substance at a specific temperature and pressure will remain constant, which is why it is often used as a unique identifying characteristic.
