1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
How does a fuel engine work?
  1. Sep 10, 2009 #1
    Seems like a stupid question, to me. But well, Im stupid aswell, so it fits me.
    Its something I've been thinking about lately. How is the heat/buring of the fuel transformed into mechanical work?
    I've had some ideas but they are mainly stupid and the loss of energy would be massive in those.
    So how do fuel/steam engines work?
    Thanks in advace,
  3. Sep 10, 2009 #2
    Staff Emeritus
    In an internal combustion engine, the release of stored chemical energy creates thermal energy. The combustion products in the form of hot gas produced a greater volume, or greater pressure, than the products. The pressure pushes a piston, or pushes through a turbine to the lower pressure exit downstream. Pressure on an area produces a force. The force on a piston is transmitted to a crackshaft, which produces a torque, or the force on a set of turbine blades causes moment on the blade, which tranmits a torque to the shaft of the turbine.
    In addition, the expansion of hot gases in a jet or rocket engine also represents a change in momentum. The thrust or force of a jet/rocket is related to the exhaust (exit) velocity of the hot gases.
    A steam cycle works much the same way. Liquid water is pumped into a heat exchanger (boilder) where it absorbs heat and changes phase going from liquid to gas. The gas occupies greater volume, and by virtue of the conservation of mass (continuity), the gas, which is constrained on one or two dimensions expands. That expansion means the gas has a higher velocity/momentum than the liquid. The steam flow passes through a turbine, and the momentum/energy of the flow pushes on the turbine blades, which like the example of the combustion turbine blade above, causes a torque on the turbine shaft.
    A rotating shaft can be used via a transmission system to turn wheels of a vehicle (car, truck, motorcycle) or propeller (aircaft or ship) or generator shaft (electrical generator) or a motor or mill machinery.
    So it goes something like thermal energy -> mechanical rotational energy, and optionally mechanical energy -> electrical energy
  4. Sep 10, 2009 #3
    Hm, I wasnt so wrong after all..
    Thanks, helped much !
  5. Sep 10, 2009 #4
    Staff Emeritus
    The efficiency of the process is quite variable.
    Commercial nuclear power plants based on the steam (Rankine) cycle have thermal efficiencies of ~32-37% depending largely on the turbine designs (particularly the blade designs).
    Fossil (coal, oil, gas - fired) power plants have efficiencies of 34-40% depending on the amount of superheat.
    Gas fired (Brayton, combustion turbine) can achieve ~42% efficiency. Aeroderivative combusion turbines have become quite efficient compared to combustion turbines of 30 to 40 years ago.
    Adding a steam (Rankine) cycle to a gas-fired combustion turbine cycle can yield 53-62% thermal efficiency.
  6. Sep 10, 2009 #5
    Staff: Mentor
    Wiki has a good animation of the internal workings of a car engine (otto cycle): http://en.wikipedia.org/wiki/Four-stroke_engine
    The various cycles are all pretty similar, having 4 similar steps.
Similar Threads - does fuel engine Date
I What physics does this BVP represent? Thursday at 2:04 PM
I What does this notation mean? Tuesday at 4:20 PM
What does a negative potential energy mean? Mar 2, 2018
Does the Earth have potential energy? Mar 2, 2018
How much fuel does cassini have on board? Jun 13, 2004
