How does a vacuum motor work?
  • Thread starter slee95
I was wondering about the how the suction works? I got this cordless vacuum broom for free and it has terrible suction. It runs on like 7 or 8 recharge c battery's and I was wondering if i increased the amperage or voltage would the motor run faster and have more suction?
Answers and Replies
I would not recommend increasing the volts/amps past the design specs, this will likely cause the motor to have a reduced lifetime, and may actually be dangerous to you (electrocution, motor catching fire / bursting).
In terms of how these work, many of them are turbine based - i.e. a radial turbine. But there are many many variations as you can imagine.
In general I would say that you won't be able to fix it yourself. The parts may be very tight tolerance that you can't replicate without CNC machines.
AlephZero
7,002
294
The clue is probably in the word "free". Designing and building an efficent compressor isn't easy. Probably the best you can hope for is that it produces a fairly high volume of air flow, not a high suction pressure with the inlet blocked.
So increased air flow to the motor should increase the suction of the vacuum?
Related Threads on How does a vacuum motor work?
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
11K
D
