- #1
d4rr3n
- 53
- 0
I'm trying to understand by what mechanism a whip can multiply the velocity of the initial arm motion until it reaches the speed of sound, how is it doing this?
It's not the tapering, it's the throwback at the end of the line:d4rr3n said:I have found that you can easily crack a leather cord with no tapering, therefore the belief that the phenomenon is due to the mass variance along the length of the whip is incorrect.
Your "therefore" does not follow.d4rr3n said:I have found that you can easily crack a leather cord with no tapering, therefore the belief that the phenomenon is due to the mass variance along the length of the whip is incorrect.
A whip is able to break the speed of sound by creating a sonic boom, which is a loud noise caused by the sudden release of pressure built up from the whip's movement. When the whip is cracked, the tip of the whip moves faster than the speed of sound, creating a small sonic boom.
The sonic boom is caused by the whip's tip moving faster than the speed of sound, creating a shockwave that travels through the air. This shockwave creates a sudden change in air pressure, resulting in the loud noise we hear.
When a whip is cracked, the handle is moved quickly, which creates a wave that travels down the length of the whip. This wave causes the tip of the whip to move at a high speed, breaking the sound barrier.
The main factor that affects the speed at which a whip breaks the sound barrier is the length of the whip. A longer whip will have a longer wave and therefore be able to reach higher speeds. The material and flexibility of the whip also play a role in its speed.
Cracking a whip and creating a sonic boom can be dangerous for both the person cracking the whip and those around them. The sudden release of pressure can cause damage to the ear and hearing, and the whip itself can cause injury if not used properly. It is important to take precautions and be trained in proper whip cracking techniques before attempting to break the speed of sound with a whip.
