How does this work? (card trick)
  • Thread starter hereandnow672
  • Tags
    Work
In summary, the card trick works because you always end up forcing the selected card to the correct position.
It's an instruction manual on how to do a card trick.
What do you mean "figure it out"? It's there explained for you.
I suppose I should have said WHY does this work...
Because the way you handle the cards means you always end up forcing the persons card to the correct position.
If you follow the steps through with a deck of cards, you should be able to track the location of the card each time and follow it to the final location.
Yes, but WHY?
Why does this sequence of events yield the same results every time?
hereandnow672 said:
Yes, but WHY?
Because that's the point of the card trick.
hereandnow672 said:
Yes, but WHY?
DO THE TRICK!
(Stop 'SHOUTING')
If you follow the steps through and track the card, you will notice the pattern being used.
It really wouldn't take that long, perhaps a few dummy runs of the trick with you performing both parts. Certainly a lot easier than someone trying to explain it here.
I've done it and it's easy to see, so give it a go.
hereandnow672 said:
Yes, but WHY?
Remember, the column, where the chosen card is, is in the middle of the other two.
When you lay the cards the second time, the cards that were formerly in the first column now constitute the first three cards of the first column and the first two cards of the other columns.
The cards in the column chosen will be in positions 4 and 5 of the first column, 3 to 5 of the second column and 4, 5 of the third column.
When the column is chosen again, it will have at most three cards belonging to the first chosen column.
As the cards are laid again, they will split between the three columns, so, when the column is chosen, ypu have already identified the card: it will be the 4th card in the chosen column (or the 11th after you put that column beneath another).
1. How does this card trick work?
The card trick works by using a combination of sleight of hand and misdirection to create the illusion of a random selection of cards. The performer often uses a pre-determined set of cards and manipulates them in a way that appears to be random to the audience.
2. Can you explain the mechanics behind this card trick?
The mechanics of a card trick can vary depending on the specific trick being performed. However, most card tricks involve techniques such as palming, false shuffling, and forcing a card to create the illusion of a random selection.
3. How can I learn to do this card trick?
Learning to perform a card trick requires practice and dedication. It is important to first understand the basic mechanics and techniques behind the trick and then practice them until they become second nature. There are also plenty of online tutorials and instructional books available to help you learn specific card tricks.
4. Why does this card trick work on some people but not others?
The effectiveness of a card trick can vary depending on the individual's level of attention and susceptibility to misdirection. Some people may be more easily fooled by the performer's techniques, while others may have a more critical eye and be less likely to fall for the illusion.
5. Is there a scientific explanation for how this card trick works?
While there is no specific scientific explanation for how a card trick works, it can be attributed to principles of psychology, perception, and physics. By understanding how the brain processes information and how the laws of physics can be manipulated, a performer can create an illusion that appears to defy logic and reality.
  • General Discussion
  • Set Theory, Logic, Probability, Statistics
