How far does the car slide?
  • Thread starter kylejustin
kylejustin
I am stuck on the last problem for my homework. It seems to me like the problem doesn't have enough information to complete. I'd really appreciate any tips.
A car traveling along a level road as a speed V slams on the brakes and skids to a stop. If the force of friction on the car is half the car’s weight, how far does the car slide? (Hint: Use work-energy theorem and solve for d)
OK, so I know the following:
W=Fd
KE=1/2mv^2
Work=Change in KE
To use the work energy theorem, I need to know the KE. The find the KE, I meed to know either the mass of velocity. The problem tells me that the force of friction is 1/2 the car's weight, but that still doesn't give me any numbers to work with. This is where I'm stuck.
Answers and Replies
ZapperZ
Staff Emeritus
Education Advisor
Insights Author
35,981
4,710
Take note that we DO have a homework section. Do not post these in the main Physics section.
Zz.
LeonhardEuler
It is common to want to work with numbers but here, as is often the case, it is better to work the problem out with symbols and plug the numbers in in the last step. Keep the car's mass as "m". By the time the problem is over (which is not a long time) the "m" will cancel out and you will have your answer.
willworkforfood
54
W = Fd
KE = 1/2mv^2
Work = Change in KE
The change in KE is asking for the derivative of KE, because change over time is another application of the derivative. The derivative d/dv for (1/2)mv^2 is Change in KE = mv
Therefore you can plug the change in KE into the final equation
mv = Fd and solve for d.
kylejustin
First, thanks for the tips, but I just am not getting it. Is my final answer going to be a number?
LeonhardEuler
It won't be a number, it will be an expression in terms of the given speed V and the acceleration due to gravity, g.
Do you know how to express the friction force in terms of m and g? Once you do its sraight foward to set the work equal to the change in kinetic energy and solve for d.
The change in KE is not the derivative of the KE. The rate of change of KE with respect to some other variable would be the derivative, but not the total change.
HallsofIvy
43,010
969
Since the car has an initial speed of v, its initial kinetic energy is (1/2)mv2. When it stops (v= 0) its kinetic energy is (1/2)m02= 0. Okay, the work done (by the friction) must be (1/2)mv2.
You are told that the friction force is "half the cars weight" which is (1/2)mg. (g= 9.81 m/s2.) You find the work done by integrating force time distance which with constant force is "force times distance" or (1/2)mgd. If (1/2)mgd= (1/2)mv2, what is d?
Suggested for: How far does the car slide?
  • Last Post
9K
10K
  • Last Post
  • Last Post
