What contributes to proton mass besides quark mass?
  • Thread starter big_bounce
  • Tags
    Mass
In summary: The QCD potential rises indefinitely at infinity, and approximates a harmonic oscillator potential (positive).In summary, the proton mass is due to the energy of relativistic quarks and gluons. There is no potential to start with, and at short distances it is free (asymptotic freedom).
big_bounce
102
Hello all .
We know about 95 percent to 98 percent of proton mass is not contributed by quark mass. In truth, most proton mass is derived from interaction energy between the quarks .
MY question is how interact makes mass ?
the mass means inertial mass or relative mass ?
It's standard rest mass; w/o using a particle collider or something like that you can't see that the mass is caused by interaction.
In quantum field theory you can in principle do the following: find an eigenstate |E,p=0> of the Hamiltonian H and the momentum operator P such that
H|E,p> = E|E,p>
P|E,p> = 0
b/c p=0, whenever E>0 this is due to interaction (kin. energy is zero)
Can E<0?
Also I thought bound state energies are always negative, so if anything, shouldn't the proton mass be less than the sum of the quark masses?
E<0 is not reasonable for a particle mass, but E=0 is.
The idea of bound states which are lighter as their constituents makes some implicit assumptions which are no longer valid in QCD
- it means that one can identify a fixed, finite number of constituents (quarks, gluons)
- it means that one can add rest masses to get the mass of the bound state (- mass defect i.e. binding energy)
- it often starts with a potential and its energy levels
In QCD
- the number of constituents is not fixed; it has to be derived from the theory; and it turns out that it becomes scale dependent
- the kinetic energy of quarks and gluons dominates the total mass; so the quarks and gluons are highly relativistic
- there is no potential to start with
So having relativistic quarks and gluons it becomes clear the the proton rest mass is due to the energy of it's 'constituents'
Can E<0? Also I thought bound state energies are always negative, so if anything, shouldn't the proton mass be less than the sum of the quark masses?
Not in this case. The QCD potential rises indefinitely at infinity, and approximates a harmonic oscillator potential (positive).
tom.stoer said:
In QCD
There has to be a potential or else wouldn't the high kinetic energy of the quarks and gluons fly apart? You can estimate it with Δp ~ 1/Δx where Δx is the nuclear size?
Also, if the number of constituents is not fixed and depends on scale, but the mass of a proton is always the same, does this mean that the constituents always conspire to change their masses at each scale so that their total mass equals the proton mass?
Also, can you find the mass of a bound state via the propagator? Take the photon propagator. Technically, shouldn't there be an isolated pole at the bound state of an electron and positron? I don't ever recall seeing this though in the photon propagator.
O okay. The harmonic oscillator potential has positive energy. Actually, I don't ever recall a quantum system that has negative energy. Classically two particles attracted to each other can be very close and have negative energy.
So the QCD potential is a harmonic oscillator at large distances. But at short distances, isn't it free (asymptotic freedom)? Is there a transition zone?
Also, if the number of constituents is not fixed and depends on scale, but the mass of a proton is always the same...
"Not fixed" does not mean "changing in time." The proton wavefunction is an eigenfunction of H. It means "not sharply determined." The proton wavefunction is a superposition of parts which contain different number of partons.
Chemical compounds such as a molecule of water, atomic nuclei such as 56Fe. A molecule of water has slightly less mass than the masses of its constituent parts (two atoms of hydrogen and an atom of oxygen), and a 56Fe nucleus weighs slightly less than the sum of the masses of 30 neutrons and 26 protons. Note the stark contrast to the situation where the mass of a proton vastly exceeds the sums of the masses of two up quarks and one down quark.
geoduck said:
Can E<0?
There's no way to free a quark from a bound state, so the definition of a quark's mass comes from the idea of asymptotic freedom, which is to say that the strong force goes away at short distances. This is totally opposite of the electric force, which goes away at long distances.
If you could somehow get a lone quark, it's mass would be something like infinite, so the proton does indeed have less mass.
Please be careful; there is no potential U(x) in QCD!
The linear potential is a derived quantity, a result, and expectation value, not an input like in Standard QM.
In QCD the interaction is due to a Coulomb gauge Hamiltonian (plus other terms); for a reference you may have a look at slide 4ff of http://www.ectstar.eu/meetings/ConfsWksAndCollMeetings/ConfWksDocument/2011/Talks/Binosi/Reinhardt.pdf
No one said the QCD potential was an input.
And no one said it isn't; we should be clear about that
1. How does interaction affect mass?
Interaction affects mass by changing the energy and momentum of particles within a system. This can cause an increase or decrease in mass depending on the type of interaction and the resulting change in energy and momentum.
2. Can interactions create mass?
Yes, interactions can create mass through processes such as particle collision or pair production. These interactions can convert energy into mass according to Einstein's famous equation, E=mc^2.
3. How do strong and weak interactions contribute to mass?
The strong and weak interactions are responsible for holding particles together and determining their properties. These interactions contribute to mass by providing the energy and forces that bind particles together and give them their mass.
4. How does the Higgs field interact to give particles mass?
The Higgs field is a fundamental force field that permeates the universe. It interacts with particles and gives them mass through a process called the Higgs mechanism. This process involves the Higgs field breaking the symmetry of other fundamental forces and giving particles their mass as a result.
5. Can mass be changed through interactions?
Yes, mass can be changed through interactions such as nuclear reactions or particle collisions. These interactions can result in the conversion of mass into energy or vice versa, altering the overall mass of a system.
  • Quantum Physics
