How is GR not proven?
  1. May 29, 2015 #1
    Hi!
    So I have noticed that phenomena, like gravitational lensing, are proven to exist, and GR is the only logical reasoning for them? If those parts of it have been proven, how could GR be possibly wrong? And if it was correct, wouldn't there have to be a way to make it work on a quantum level, as classical physics needs to be consistent with quantum physics? Please help me understand why this whole controversy is going on when much of GR has been experimentally proven.
    Thanks!
    P.S. Please don't get mad if this question is idiotic, I am only 13 and I have found PF a great place to expand my knowledge.
  3. May 29, 2015 #2
    russ_watters
    Staff: Mentor
    Welcome to PF!
    GR is extremely well proven and while there is some potential conflict with QM on very small scales, it isn't really a controversy. Mostly it is just an issue of approaching physics from opposite scales and trying to meet in the middle/where they overlap.
    GR is pretty much universally accepted as a highly successful theory.
    Note though that in science it isn't possible, even in principle, for a theory to be 100% proven. But GR is well above 99%.
    Btw, It is great that at your age you are thinking about such things/asking such questions. It's the opposite of idiotic.
  4. May 29, 2015 #3
    Orodruin
    Staff Emeritus
    2017 Award
    Let me just add that theories are not going to be wrong in a true or false way. Newtonian gravitation is a very useful theory as long as we are dealing with (relatively) small masses moving at velocities much smaller than the speed of light. That it fails in some scenarios does not mean that it is not still a useful theory.
  5. May 29, 2015 #4
    But where do they overlap? I thought that the controversy is because people say QM and GR can't be consistent at all.
  6. May 29, 2015 #5
    GR requires continuous space, meaning no matter how small of a distance you can think of, you can still cut it in half and have an even smaller distance. In QM, space stops existing at something called the Planck length.
    Usually gravity doesn't matter in QM interactions because it's really weak compared to everything else at that scale, and QM doesn't matter in gravitational interactions because of the scale at which gravity works. There are places in the universe where the super tiny QM world and the super weak GR world have to meet: black holes. Super super tiny, but super super massive.
  7. May 29, 2015 #6
    Then why do people say they can't coexist? It seems like they can.
  8. May 29, 2015 #7
    Because the mathematics of GR require infinitely small distance and mathematics of QM require lengths no smaller than 1.61619926E-35m
  9. May 29, 2015 #8
    pervect
    Staff Emeritus
    Theories aren't really "proven" by science, they're tested. GR has passed all the tests so far, but there's always the possibility that it will fail some future test which will require it to be modified or extended or even replaced outright. So theories can fail a test, by which they are disproven, even though they can't be "proven" by testing. Even if a theory has passed every test that has been made so far, there is no guarantee it will contiue to meet future tests. There will always be tests that haven't been made. The concept of "domain of applicability" is relevant here, but this is a good place to stop, I think.
    For some historical perspective, look how Newtonian gravity, which worked quite well, was eventually superseded by a new theory, GR. Newtonian gravity was "almost" right, but under extreme enough conditios or sensitive enough measurements, it has been disproven.
    For one an example of a possible theory of gravity that is consistent with observations to date but is different than GR, take a look at http://en.wikipedia.org/wiki/Einstein–Cartan_theory, sometimes call ECKS (Einstein-Cartan-Kibble-Sciama) gravity. It's got some unique physical predictions, which, unfortunately, are very difficult to test.
    For a recent example of an attempt to replace GR that failed to match experiment, see Self Creation Cosmology, http://arxiv.org/abs/gr-qc/0302026. It made some different predictions about gravity probe B results, which turned out to be false, so it's fallen by the way side.
  10. May 29, 2015 #9
    wabbit
    Indeed they can, most of the time - it is only for some phenomena involving very short distances, etc. that there is an issue. Actually, as I understand it, it seems one difficulty in the elaboration of a theory of quantum gravity (i.e. "whatever theory is needed to fully resolve the tensions between GR and QM") is precisely that they work together too well: it is very difficult to find clear observational evidence of phenomena in the regimes where both are at play, because such phenomena are rare or extreme. So while for instance electromagnetism or other theories were developped on the basis of a large body of experimental data, and could be tested against new experiments, quantum gravity faces a rarity (not to say a total absence as things stand today) of such tests and data to help pick between alternative proposals.
  11. May 29, 2015 #10
    russ_watters
    Staff: Mentor
    Depends on exactly what they mean when they say that. Seems to me that they can and do. You just pick the one most appropriate to the problem you are working on and unless it is a special problem where they overlap (like with black holes), there is no issue of "coexisting". It's like your fork and spoon "coexisting" on your dinner table: just because you used your spoon to eat your soup doesn't mean your fork can't still be useful to eat your steak.
  12. May 29, 2015 #11
    Bandersnatch
    It's just that those lazy physicists would oh, so love to have a spork instead.
  13. May 29, 2015 #12
    vela
    Staff Emeritus
    Education Advisor
    I wouldn't say the theories can't coexist. They're both useful in their domains. It's similar to the relationship between Newtonian mechanics and special relativity. In a sense, Newtonian mechanics is wrong because it doesn't correctly describe what happens at speeds close to the speed of light. It clearly conflicts with special relativity in these situations, but when you're calculating what happens when a block slides down an inclined plane, you don't pull out the full machinery of special relativity; you use Newton's laws of motion because they give answers that are good enough. Scientific theories and models persists not so much because they're right or wrong but because they make useful predictions.
    Nor would I say there's a controversy. It would be better to say that the GR and quantum mechanics are known to be inconsistent with each other. In regimes where both gravity and quantum mechanical effects matter, the two theories conflict, and we don't yet know how to resolve that conflict.
    I don't know if I'd go so far as to say that space stops existing or that QM requires lengths no smaller than the Planck length. The Planck length is just a length scale. It's the scale at which we believe quantum mechanical effects and gravitation both matter.
  14. May 29, 2015 #13
    Ibix
    This is a bit metaphorical, but think of a street map of your town. It probably treats your town as flat. Similarly, a street map of my town treats my town as flat. Both of those are fine, but if either of us try to extend our maps to cover each other's town, we will start to get very funny looking results - more so the further apart we live.
    Both maps are fine and can coexist peacefully, as long as we don't try to extend them too far.
    This is analogous to the QM versus GR situation. QM is a good "map" of physics on extremely small scales. GR is a good "map" of physics on very large scales. As long as we don't push either theory too far, they coexist peacefully.
    The difference between the maps and the physics is that we know what we're doing wrong with the maps - ignoring the curvature of the Earth - but not with the physics. We haven't yet managed to make precise enough measurements to see exactly how it's going wrong, although we can see some things look funny.
    Does that help?
  15. May 29, 2015 #14
    Is this why many sources say they can't coexist?
  16. May 29, 2015 #15
    atyy
    General relativity is consistent with quantum mechanics, in the same way that electrodynamics is consistent with quantum mechanics.
    Both are excellent effective quantum field theories.
    http://arxiv.org/abs/1209.3511
    The effective field theory treatment of quantum gravity
    John F. Donoghue
  17. May 30, 2015 #16
    russ_watters
    Staff: Mentor
    Crackpot posts and responses deleted. Don't mind the noise, Isaac...it happens.
  18. May 30, 2015 #17
    Isaac, I wish I had your knowledge when I was 13. WELL DONE!
    Keeping in mind all the above reasons why the two theories do 'work' in their own domains and are 'tested' rather than 'proved', here is a perspective that is somewhat different than those posted. Here are some reasons why some prominent scientists think there is a fundamental and troubling distinction betwee GR and QM...that "... we have not been able to combine these new insights into a novel coherent synthesis, yet...."
    Carlo Rovelli has a non mathematical synopsis explaining why he takes this view....
    "...The present knowledge of the elementary dynamical laws of physics is given by the application of QM to fields, namely quantum field theory (QFT), by the particle–physics Standard Model (SM), and by GR. This set of fundamental theories has obtained an empirical success nearly unique in the history of science: so far there isn’t any clear evidence of observed phenomena that clearly escape or contradict this set of theories..... But, the theories in this set are based on badly self contradictory assumptions....
    In fact he seemed quite concerned when he wrote this:
    "....In spite of their empirical success, GR and QM offer a schizophrenic and confused understanding of the physical world. The conceptual foundations of classical GR are contradicted by QM and the conceptual foundation of conventional QFT are contradicted by GR. Fundamental physics is today in a peculiar phase of deep conceptual confusion.
    You can find some specific reasons why he thinks this....for example discrete [quantized] versus continuous space, already mentioned above, and a fixed versus a dynamic space time backgroynd....
    His paper is here...and while some of the terminology is over my head, the first few pages will likely give you some helpful insights why some people are concerned about having two theories.
    Relational QM
    http://arxiv.org/abs/quant-ph/9609002v2
  19. May 30, 2015 #18
    Thank you very much
  20. May 30, 2015 #19
    So QM requires a quantized space (which, if I am correct, means that the Planck leingth is the fundamental/smallest unit of space) and GR uses infinitesimal units of space, right? What I'm hearing is that they explain what they need to explain correctly, but something that includes both can't be explained in quantized space and not quantized space. Is there a possibility that another set of laws is needed to explain these objects?
  21. May 30, 2015 #20
    Isaac....." another set of laws is needed"...???....... great question....again!!
    maybe....seems it is an open question.
    Rovelli says [to me] in a 2008 paper : maybe we don't understand what QM is telling us because we don't have a valid starting point.
    Keep in mind his paper is a set of ideas rather than a fully formulated complete theory....but look at the 'acknowledgements' at the end of the paper: a list of prestigious people who helped him develop the ideas.
    So your question in a modified form apparently interests others....
    Here is what I took from his paper:
    [Some people summarize the many different interpretations of QM as "Shut up and calculate". I take that to mean while many of the people doing the calculations may interpret their meaning differently, may describe differently what is going on, most all agree on the calculation methodology....because such calculations pass experimental test...... as already described by others. ]
    Rovelli says:
    "...Special relativity is a well understood physical theory, appropriately credited to Einstein’s 1905 celebrated paper. The formal content of special relativity, however, is coded into the Lorentz transformations, written by Lorentz, not by Einstein, and before 1905. So, what was Einstein’s contribution? It was to understand the physical meaning of the Lorentz transformations....... the Lorentz transformation were perceived as “unreasonable” and “unacceptable as a fundamental spacetime symmetry”, even “inconsistent”, before 1905; words that recall nowadays comments on quantum mechanics. The physical interpretation proposed by Lorentz himself ..... was a physical contraction of moving bodies, caused by a complex and unknown electromagnetic interaction between the atoms of the bodies and the ether. It was quite an unattractive interpretation, remarkably similar to certain interpretations of the wave function collapse presently investigated! Einstein’s 1905 paper suddenly clarified the matter by pointing out the reason for the unease in taking Lorentz transformations “seriously”: the implicit use of a concept (observer-independent time) inappropriate to describe reality when velocities are high. ....
    Here I consider the hypothesis that all “paradoxical” situations associated with quantum mechanics –as the famous and unfortunate half-dead Schrodinger cat ... may derive from some analogous incorrect notion that we use in thinking about quantum mechanics. (Not in using quantum mechanics, since we seem to have learned to use it in a remarkably effective way.) The aim of this paper is to hunt for this incorrect notion, with the hope that by exposing it clearly to public contempt, we could free ourselves from the present unease with our best present theory of motion, and fully understand what does the theory assert about the world.
    Furthermore, Einstein was so persuasive with his interpretation of the Lorentz equations because he did not append an interpretation to them: rather, he re-derived them, starting from two postulates with terse physical content –equivalence of inertial observers and universality of the speed of light– taken as facts of experience. It was this re-derivation that unraveled the physical content of the Lorentz transformations and provided them a convincing interpretation. I would like to suggest here that in order to clarify the physical meaning of quantum mechanics, a similar result should be searched: Finding a small number of simple statements about nature –which may perhaps seem contradictory, as the two postulates of special relativity do– with clear physical content, from which the formalism of quantum mechanics could be derived. In other words, I have a methodological suggestion for the problem of the interpretation of quantum mechanics: Finding the set of physical facts from which the quantum mechanics’s formalism can be derived. To my knowledge, such a derivation has not been achieved yet. ....... I expect that if this program could be completed, we would at long last begin to agree that we have understood quantum mechanics.
    Relational Quantum Mechanics
    http://arxiv.org/PS_cache/quant-ph/pdf/9609/9609002v2.pdf
Similar Discussions: How is GR not proven?
  1. How innaccruate is GR? (Replies: 26)
Loading...
