How is realism understood in QM?
  • I
  • Thread starter Lynch101
  • #76
Demystifier
Insights Author
3,709
Replacing Bohm's continuum model by a lattice model does not preserve Bohm's beables.
I think changing a continuum field with a field on a lattice is a minor change of beables.
  • #77
A. Neumaier
Insights Author
2019 Award
7,476
3,377
The change robs momentum modes from being beables, hence is drastic.
  • #78
Demystifier
Insights Author
3,709
I think those two field ontologies are equivalent. If one knows the actual value of ##\tilde{\phi}(k)## and if one defines
$$\phi(x)\equiv \int dk\, e^{ikx} \tilde{\phi}(k)$$
then one also knows the actual value of ##\phi(x)##.
It may be illuminating to see what is it analogous to in particle ontology. It is not analogous to proposing that the beable is the particle momentum ##(p_x,p_y,p_z)## instead of the particle position ##(x,y,z)##. Instead, it is analogous to proposing that the beables are the spherical position coordinates ##(r,\theta,\varphi)## instead of Cartesian position coordinates ##(x,y,z)##.
Bohm in his paper is not explicit about that, but I think it's implicit in his Eq. (A1). Moreover, in the book by Bohm and Hiley (The Undivided Universe) it is quite clear that those two ontologies are considered equivalent.
  • #79
A. Neumaier
Insights Author
2019 Award
7,476
3,377
This works only in the continuum.
From ##x## limited to a finite lattice (as in lattice models) one cannot go back to Bohm"s momenta ##p##. Thus lattice ontologies are essentially different from Bohm"s ontology.
  • #80
Demystifier
Insights Author
3,709
I think you are nitpicking. It's well known how to write the corresponding equation on the lattice. For a scalar field that's indeed very simple.
  • #81
A. Neumaier
Insights Author
2019 Award
7,476
3,377
How do you get beables with arbitrary wave vector from the beables of a scalar field theory on a finite lattice??? It is well-known to be impossible by Nyquist's theorem.
  • #82
Demystifier
Insights Author
3,709
The following is taken from the book "Quantum Fields on a Lattice" by Montvay and Munster. I think Eqs. (2.4) and (2.6) answer your question. Or do I miss something?
  • #83
A. Neumaier
Insights Author
2019 Award
7,476
3,377
What you miss is that ##p## is restricted to a finite number of values, unlike Bohm's beables, which are defined for all ##p##. Thus a lattice theory has too few beables compared to Bohm's.
  • #84
A. Neumaier
Insights Author
2019 Award
7,476
3,377
In addition, space is not periodic, and the argument you quoted only works in the periodic case.
  • #85
Demystifier
Insights Author
3,709
Bohm's beables on a continuum are defined for all ##p##, but Bohm's beables on a lattice are defined for some ##p## only. Bohm himself haven't study the lattice explicitly, but it's straightforward to modify the theory by replacing the continuum with the lattice, so it's justified to still refer to the resulting theory as "Bohm's".
Perhaps the source of our disagreement is philosophical. While for you the continuum and the lattice are conceptually totally different things, for me the continuum is conceptually just a lattice in the limit ##a\to 0##.
So from my point of view, your objection is just irrelevant nitpicking.
  • #86
308
119
In a field theory, the field beables are ##\phi(x)##. In the corresponding lattice model, the corresponding beables are ##\phi(n)## for ##n\in\mathbb{Z}^3_N\subset \mathbb{R}^3##. So it is simply a subset. There is also no problem with the momentum variables, which are in both cases simply ##\pi(x) = \dot{\phi}(x)## (and have nothing to do with the momentum of the particles, which are in a field ontology irrelevant pseudo-particles similar to phonons).
(Not sure what you name "Bohm's beables", but in
Bohm.D., Hiley, B.J., Kaloyerou, P.N. (1987). An ontological basis for the quantum theory, Phys. Reports 144(6), 321-375
field beables are used.)
  • #87
A. Neumaier
Insights Author
2019 Award
7,476
3,377
You'd read my posts within their context. See Post #59. Bohm's beables are the transverse momentum modes of the vector potential. These cannot be defined on a finite, nonperiodic lattice.
  • #88
308
119
Ok. That means, another proposal made by Bohm et al later is better, it does not have your problem:
Of course, for vector gauge fields the Wilsonian lattice variant is even better than the straightforward one.
  • #89
A. Neumaier
Insights Author
2019 Award
7,476
3,377
We were discussing an electron in an electromagnetic field, where @Demystifier referred in post #58 to this paper of Bohm. Instead, you propose references for scalar field theories that don't apply.
Where does this variant treat an electron in an electromagnetic field? Please refer to a paper that compared to #58 gives an improved answer.
  • #90
308
119
The formulas have been given, for simplicity, for scalar field theory, but it is said that the field ontology works for other bosonic fields too. But, ok, here is a paper which describes explicitly the EM field:
Kaloyerou, P.N. (1994). The causal interpretation of the electromagnetic field. Physics Reports 244, 287-358
Related Threads on How is realism understood in QM?
  • Last Post
11K
  • Last Post
  • Last Post
