- #36
russ_watters
Mentor
- 23,161
- 10,368
Because it is under tension!A.T. said:But the distance between the wire ends is constant...
No, for the "moving" end (assume one end is fixed relative to its local stars), the distance to its local stars is increasing so the speed must also be increasing: speed is a function of distance in the Hubble parameter. The "local stars" are accelerating past/away from it....so both ends move at some constant speed relative to their local stars.
It looks to me like this is similar to unrolling a wire vertically into a black hole. After the distance gets large enough, gravity/the Hubble flow provides the force to do the unrolling and the tension gets larger and larger as you unroll it, as a function of distance. After a while, if you don't stop unrolling it, the tension gets high enough to break the wire. If you do stop unrolling it, the tension just becomes constant.
Note: Nugatory already explained this in post #15.
