How many turns On the Coil
  1. Nov 12, 2012 #1
    Hello there
    Its a air core coil I am not too sure how to calculate the
    number of turns I have to wind.
    Specs are below
    Height : 4mm
    Outside D: 9.5mm
    Inside D :7mm
    Coil wire thickness : 40 AWG / 0.08mm
    Coil resistance : 55 Ohms
    Coil weight : 0.7g
    Important figures highlighted. I have made a detachable bobbin.U sing self bonding wire.
    coil is air -core.
    How can I calculate the number of turns that i would require to make this coil
    Thank you
    Edit/Delete Message
  3. Nov 12, 2012 #2
    Turns = turns per layer * number of layers
    turns per layer = height / wire thickness = 4 mm/0.08 mm = 50
    number of layers = (OD-ID)/(2*wire thickness) = (9.5-7)/(2*0.08 ) = 31.25 = 31 layers
    therefore, Turns = 31 * 50 = 1550
  4. Nov 12, 2012 #3
    oh btw that's assuming rectangular packing, if its triangular packing then divide the result by 0.78
  5. Nov 13, 2012 #4
    Having been in the transformer business, I'm very pessimistic.
    Phelphs dodge gives for #40 Bondeze wire a nominal diameter of 0.0037 inches.
    This works out to a diameter of 0.0939 mm.
    When hand winding you usually get maybe 60% fill.
    #40 wire is THIN, so is extremely difficult to work with.
    Good Luck
  6. Nov 13, 2012 #5
    Carl is right, AWG 40 breaks incredibly easily. 60% is also a more practical number, so multiply the result I originally gave you by 0.6 (or if using triangular packing, which I suspect is what it would come down to, divide by 0.78 then multiply by 0.6)
  7. Nov 14, 2012 #6
    You need 15.4m of wire to achieve the resistance. 0.08mm needs care.
    With a setup that rotates the coil former you can still make a perfectly compact coil of 0.08mm by hand but only with training and good hands.
    Then each layer packs nearly 50 turns, I estimate 47 (again under good conditions...) so the first layer packs 1.0m and the latest 1.4m with 1.2m as a mean, so you need 13 layers.
    I could never pack properly successive layers in the same direction (wire returns makes a mess), nor did I see a coil made this way, so each layer takes >0.08mm and the 13 perfect layers fit well in OD=9.5 ID=4
    BUT
    you'd go crazy before finishing the 13 layers. With said training and good hands you achieve 4 layers or 50 turns with this tiny wire, then you throw all through the window.
    Next solution: pack the wire disordered, taking advantage of the available 50% filling factor. For 650 turns of tiny diameter you DO need to rotate the coil former or you'll break the wire. At 50% filling you can't make much of a mess, the winding must already look good.
Loading...
