How to Calculate the force to push a wheelchair up a ramp?
In summary, to push a wheelchair up a ramp, you will need to overcome the normal force and the rolling resistance.
TommyH
TL;DR Summary
How do I calculate the required push force (in kgf) for pushing a wheelchair up a ramp?
- the ramp has a 5 degree incline
- the weight of the chair and person in it totals 96.8 kg
- the wheelchair has 4 wheels, all of equal diameter (15 cm)
- the wheels on the wheelchair have a rolling coefficient of friction with the floor of 0.1
I am really stuck on this. Any help would be greatly appreciated thank you
We will try to work you through this.
Can you tell me what two forces need to be overcome before the wheel chair will begin moving up the ramp?
Have you tried googling "forces on an incline"?
Normal force and frictional force?
The frictional force requires knowing the normal force - the force normal (perpendicular) to the surface of the ramp.
How do you calculate that normal force?
The first force I was considering was the frictional force. But there is a second force that is very important. It's the one that you will need to compute the normal force.
Also, by all means, take @A.T. 's advice and Google "forces on an incline". You will get to pick one of many sketches of the problem.
I don't think either of those is relevant. Friction between the wheels and the ramp doesn't contribute to a retarding force (unless the wheelchair's brakes are on, which would make no sense). The component of the weight of the wheelchair in the direction parallel to the ramp is one force, and the "rolling resistance" of the wheels is the other force that you need to overcome. The rolling resistance consists of the bearing friction for the wheels and any deformation of the wheels at the contact patches. Are the wheels pneumatic or solid rubber?
Are you familiar with trigonometry and algebra? We can show you how to calculate the force to overcome the component of the weight that is parallel to the ramp...
Also, will the pushing be done by a helper behind the wheelchair (hence a fairly continuous force at a constant speed), or by the person sitting in the wheelchair (so it will be in spurts)?
Friction between the wheels and the ramp don't contribute to a retarding force.
The problem describes a "rolling coefficient of friction" with the floor.
So friction is (half of) a good answer.
Also, it is a unit-less value.
Also, there are no units for that coefficient.
Is that meant to represent rolling resistance? The number did seem low for a coefficient of static friction...
That's how I took it.
TommyH said:
Summary: How do I calculate the required push force (in kgf) for pushing a wheelchair up a ramp?
Perhaps one reason you are stuck is that the problem conflates 'force' and 'velocity'. That is, since a resultant *acceleration* of the wheelchair is not provided, you are most likely assuming the wheelchair moves at a constant velocity. So, if the wheelchair moves at constant velocity, you can use a reduced form of Newton's second law (or two N2s in combination: one for linear motion and the other for rotational motion, connected by the assumption of rolling motion) to figure out what the applied force must be.
Well, let's give the OP an initial ballpark estimate of the force. Hopefully that helps some.
All of the wheelchairs I've pushed in healthcare settings have solid rubber wheels, and very little rolling resistance. A 5 degree incline is pretty gentle, but let's assume that the rolling resistance is a negligible retarding force. Let's also assume that a helper is pushing the wheelchair at a constant velocity. Then the force required is just the component of the weight in the direction parallel to the incline:
[tex]F = m * g * sin(5 degrees) = 96.8kg * 9.8 \frac{m}{s^2} * sin(5 degrees) = 82.7N[/tex]
82N is about 20 pounds of force. Does that help?
https://www.researchgate.net/profile/Catherine_Holloway/publication/267995686/figure/fig4/AS:669371231920138@1536601946564/5-Forces-acting-on-a-wheelchair-going-up-left-and-down-a-slope-W-is-the-weight-of.png
BTW, slightly off topic -- If there is an Abilities Expo near you, try to stop by and check it out. I worked a recent one locally on EMS standby, and I was very impressed by the wonderful uses of technology to help folks with disabilities. I won't tell you which exhibit brought me to tears, but there are plenty of great examples of human creativity to help overcome the challenges of disabilities.
https://www.abilities.com/expos/
:smile:
1. How do I calculate the force needed to push a wheelchair up a ramp?
The force needed to push a wheelchair up a ramp can be calculated using the formula F = mgsinθ, where F is the force in Newtons, m is the mass of the wheelchair and occupant in kilograms, g is the acceleration due to gravity (9.8 m/s²), and θ is the angle of the ramp in degrees.
2. What is the weight limit for a wheelchair ramp?
The weight limit for a wheelchair ramp varies depending on the type of material and design of the ramp. Generally, most ramps can support a weight limit of 600-800 pounds, but it is important to check the manufacturer's specifications for the specific ramp being used.
3. Does the length of the ramp affect the force needed to push a wheelchair up?
Yes, the length of the ramp can affect the force needed to push a wheelchair up. The longer the ramp, the more gradual the slope will be, resulting in less force needed to push the wheelchair. However, a longer ramp may also require more energy and effort to traverse.
4. Can I use an incline calculator to determine the force needed to push a wheelchair up a ramp?
Yes, an incline calculator can be used to determine the force needed to push a wheelchair up a ramp. Simply input the ramp angle and the weight of the wheelchair and occupant, and the calculator will provide the force needed in Newtons.
5. How can I reduce the force needed to push a wheelchair up a ramp?
There are a few ways to reduce the force needed to push a wheelchair up a ramp. One way is to decrease the angle of the ramp, making it less steep. Another way is to reduce the weight of the wheelchair and occupant. Additionally, using a ramp with a smoother surface and adding handrails for support can also make pushing the wheelchair up the ramp easier.
  • Classical Physics
  • Mechanical Engineering
10K
