How to divide a cylinder
  • Thread starter physior
jbriggs444
9,982
4,577
well, it doesn't work like that
you cannot have spiral holes, I told you the holes are linear across the cylinder length
but let the cylinder thing, we were talking about the circle
You also drew lines that were not straight and talked about lines going straight down the long axis of the cylinder and showed an example of straight lines across the flat end of the cylinder but then talked about holes that are circular rather than straight.
How do you expect us to answer your question when you refuse to tell us what your question is?
Edit: I think I see your objection. The "spiral" I was talking about was not a spiral down through the cylinder (like the threads on a screw) but a spiral on the surface of the end. Like the first part of the yellow brick road in the Wizard of Oz.
well, I have it clear in my mind, but I may not be able to explain it written
whatever the hole is in the base of the cylinder, the same hole goes down across its whole length
that's it
and you can have whatever shape of the hole in the base of the cylinder
but cannot be more than or less than 0.01mm^2
jbriggs444
9,982
4,577
that's it
See clarification in edit in my previous post. I am talking about a shape on the base of the cylinder. Each tiny hole can have a perimeter that is arbitrarily large, even though its area is 0.01mm2
well, if that maximizes the perimeter, yes, why not
6,892
The personal attacks are not appreciated.
Indeed. The OP has been dealt with.
That's been the basic question throughout this thread.
Related Threads on How to divide a cylinder
  • Last Post
18K
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
