1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
How to do this node analysis
  1. Aug 8, 2008 #1
    Using mesh analysis work out the currents flow through each of the three meshes. From these current values calculate the voltage of node A and node B with respect to the ground node. XX V has a value of 13.
    2. Relevant equations
    3. The attempt at a solution
    Well I figured out the mesh analysis easy enough. Obtaining, I1=.046, I2=.398 and I3=-.5908. Got to the node analysis and haven't got a clue. I came up with
    1. V1/15 = 3 + [V1 -(V2+30)/40] + [V1-V2]/10
    2. [V1-V2]/10 + [V1 -(V2+300)/40] = V2/20 + [(V2+17)/25]
    Which gave me V1 = 187.5
    V2 = 105.5
  3. Aug 9, 2008 #2
    In your two equations there is a term where you mix voltages and currents:
    1. [V1 -(V2+30)/40] where V1 is a voltage and (V2+30)/40 is a current
    2. [V1 -(V2+300)/40] the same
    Redo your equations
  4. Aug 13, 2008 #3
    [V1 -(V2+30)/40] is actually incorrectly input. It should be (V1-V2-30)/40. Not sur if that changes anything, but I think it should
  5. Aug 14, 2008 #4
    It changes, but it is not correct yet. According to KCL, the sum of the currents out of a node must be zero. Using your reference it should be:
Similar Threads - node analysis Date
Node analysis Dec 12, 2017
Solve Using Method of Node Voltages Oct 13, 2017
Calculating Node Voltage using Nodal Analysis Dec 20, 2016
Node/Mesh Analysis of a Circuit Feb 28, 2016
Super Node Analysis Oct 2, 2015
