ngheo1128
- 1
How to do you use MATLAB to solve this?
dh/dt = 0.079577-0.066169*squareroot(h)
where ho = 1.75 and hf = 1.46 and to=0
To input data into MATLAB, you can either type it directly into the Command Window or import it from an external file. To type data into the Command Window, simply use the following syntax: variable_name = [data1, data2, data3]
To import data from a file, you can use the importdata()
function.
To write a script in MATLAB, you can use the built-in editor by clicking on the "New Script" button in the Home tab. Alternatively, you can create a new file with the .m
extension and open it in any text editor. Remember to save your script before running it.
To perform mathematical operations in MATLAB, you can use the standard arithmetic operators: +, -, *, /
. You can also use built-in functions such as sin(), cos(), sqrt()
to perform more complex operations. Remember to use parentheses to indicate the order of operations.
To plot data in MATLAB, you can use the plot()
function. First, input your data into MATLAB using the methods mentioned in question 1. Then, use the plot()
function with the appropriate arguments, such as x and y values, to create a plot. You can also customize the plot using additional arguments, such as color and line style.
To save your work in MATLAB, you can use the save()
function. This will save the current workspace variables to a file with the .mat
extension. You can also use the diary()
function to save all the commands and outputs from your current session to a text file for future reference.
