madmike159
How do computers find log values, is there some sort of algorithm to find it or do they just use binary search?
A logarithm is the inverse function of an exponential. It is used to find the power to which a base number must be raised to equal a given number.
The most common algorithm used to find logarithms is the binary search algorithm. This algorithm involves repeatedly dividing the search interval in half and checking which half the target value lies in until the value is found.
Binary search is used for finding logarithms because it is a highly efficient algorithm with a time complexity of O(log n). This means it can find the logarithm of a number in a very short amount of time, even for large numbers.
To use binary search to find a logarithm, you first need to determine the base and the target number. Then, you divide the search interval in half and check if the target number is larger or smaller than the result of the logarithm function using the midpoint as the exponent. You continue this process until the target number is found.
Yes, there are other algorithms for finding logarithms such as Newton's method and the bisection method. However, binary search is the most commonly used and efficient algorithm for finding logarithms.
