• Support PF! Buy your school textbooks, materials and every day products Here!
How to find side AB?
  • Thread starter quee
Hello.
There is a problem:
"Through D on a side AB of the triangle ABC drawn a line parallel to AC intersecting BC in E. D is such that CD:DB = m:n. Find DE:AC"
So it is easy to find out that DB:AB equals to DE:AC as DE and AC are parallel. Since DB = n, there is only one need to express AB in terms of n and m. But how to do it? I tried using similar triangles, but I can't get AB through it. The trapezoid ADEC also gives no results as the second diagonal is unknown.
fresh_42
Mentor
Insights Author
2018 Award
11,721
8,250
I think you need also ##AE## and the intersection of both diagonals ##AE## and ##CD## in, say ##F##. This will make things more complicated as there will be more lengths involved, but I don't see another way to get hold on ##CD##. Then use the intercept theorem.
Thank you. Actually, I considered that there may be not enough information in the problem. Now I am convinced.
fresh_42
Mentor
Insights Author
2018 Award
11,721
8,250
I am not sure. It depends on how the result has to look like. E.g. I got for the quotient
$$\dfrac{DE}{AC} =\dfrac{n}{m} \cdot \dfrac{CD}{AD+DB}$$
but it's not clear whether this will do or not. I don't see a second equation for ##CD##.
93
39
Since ##DE## is parallel to ##AC##, you can use the similarity of triangles ##ABC## and ##ADE##. You have from the proportion that is given:
$$AD:DB = m:n \Rightarrow nAD = mDB$$
This means that ##AB = AD + DB = \left(\frac{m}{n} + 1\right) DB##. So now you have the proportion between ##AB## and ##DB## and from similarity you get the proportion between ##DE## and ##AC##.
SammyS
Staff Emeritus
930
Did you misread the given information?
Statement says: ##CD:DB = m:n##, not ##AD:DB ##.
93
39
@SammyS Indeed, I completely misread it. Apologies to the OP. In that case the exercise seems more complicated.
Might be that the method fresh gave would work, I so far don't see a clear way to get the proportion.
It is okay. Thank you for your reply.
If only $$AD:DB= m:n,$$ it would be completely obvious that $$\frac{DE}{AC} = \frac{n}{n+m}$$
But this is, unfortunately, a much harder problem. Or it may be an actual lack of some information in the problem.
Want to reply to this thread?
"How to find side AB?" You must log in or register to reply here.
Related Threads for: How to find side AB?
  • Last Post
  • Last Post
Hot Threads
