Proving Continuity and Differentiability of f(x) with Given Conditions
  • Thread starter transgalactic
  • Tags
    Proof
In summary, if a function f is differentiable and continuous on the interval [a,b], and |f'(x)|<1 for all x in [a,b], then there exists a constant 0<=k<1 such that |f(x1)-f(x2)|<=k|x1-x2| for some x1 and x2 in [a,b]. This can be proved by using the Mean Value Theorem and the fact that a continuous function on a compact interval has a maximum value, which in this case is less than 1 due to the condition |f'(x)|<1. By setting k as the maximum value of |f'(x)|, we can show that 0<=k
transgalactic
1,395
f is differentiable continuously(which means that f(x) and f'(x) are continues and differentiable) on [a,b]
suppose that |f'(x)|<1 for x in [a,b]
prove that there is 0<=k<1 so there is x1,x2 in [a,b]
i started from the data that i was given and i know that f(x) is differentiable
so
[tex]
f'(x)=\lim _{h->0}\frac{f(x+h)-f(h))}{h}
[/tex]
i use
|f'(x)|<1
so
[tex]
|f'(x)|=\lim _{h->0}\frac{|f(x+h)-f(h))|}{|h|}<1
[/tex]
so f(x) is continues and differentiable
so i use mvt on x1 and x2
[tex]
f'(k)=\frac{f(x1)-f(x2)}{x1-x2}
[/tex]
and i combine that with
|f'(x)|<1
[tex]
\frac{|f(x1)-f(x2)|}{|x1-x2|}<1
[/tex]
so
[tex]
|f(x1)-f(x2)| <|x1-x2|
[/tex]
what now?
Show that [tex]|f'(x)|\le k[/tex] for all x in [a,b] and for some 0<k<1. Hint: A continuous function defined on a compact interval has a maximum.
they sign L as the minimum of f'(x)
and they sign l as the maximum of f'(x)
then they say that k=max{|f(L)|,|f(l)|}
but its not true
i am given that 0=<k<1
and i don't know if i get the same values
why
k=max{|f(L)|,|f(l)|} equals 0=<k<1
transgalactic said:
i can't understand these words as a logical sentence
"Hint: A continuous function defined on a compact interval has a maximum."
I was referring to the http://en.wikipedia.org/wiki/Extreme_value_theorem" .
What does it tell you about the function |f'(x)| on the interval [a,b]?
You will find that is has a maximum M. Now use |f'(x)|<1 to show that M<1.
why this maximum is K ??
and not 1 ??
and not 1 ??
Use the following: If M is the maximum of |f'(x)| then there exists a point a with |f'(a)|=M (by definition), but |f'(x)|<1 for all x (including a), so what does that tell you about M?
that M<1
i have been told that l,L are the maximum and minimum points on [a,b] interval so
f'(l)<=f'(x)<=f'(L)
what is the meaning of
k=max{|f'(L)|,|f'(l)|}
why not just say that
k=f'(L)
we see that f'(L) is the maximum in the innequality
ok here is the complete proof as i see it
if we take K as maximum of the sequence
we get
|f'(x1)-f'(x2)|=|f'(c)||x1-x2|<=K|x1-x2|
but how to show that k
is 0<=k<1
we get
is 0<=k<1
Look at posts #6 and #7.
ok i agree that k<1
but its -1<k<1 because of |f'(x)|<1
not
0<=k<1
If k=max |f'(x)| then k>=0 because [tex]|f'(x)|\ge 0[/tex] for all x.
Modify your original proof where you used |f'(x)|<1 and use [tex]|f'(x)|\le k[/tex] instead to get a better estimate.
thanks
1. How do I know where to start when trying to finish a proof?
When trying to finish a proof, it is important to review the steps you have taken so far. Look for any patterns or logic that you have used throughout the proof. This will give you an idea of how to proceed with the remaining steps.
2. What should I do if I get stuck while trying to finish a proof?
If you get stuck while trying to finish a proof, take a step back and try to approach the problem from a different angle. You can also try breaking the proof down into smaller, more manageable steps. If you are still stuck, it can be helpful to consult with a colleague or professor for guidance.
3. Is it okay to use examples to help me finish a proof?
Yes, it is perfectly acceptable to use examples to help you finish a proof. Examples can often provide insight into the problem and help guide your thinking. However, be sure to also provide a general proof that applies to all cases, not just specific examples.
4. How do I know when a proof is complete?
A proof is considered complete when you have successfully shown that the statement or theorem is true using logical reasoning. This typically involves using previously established theorems, definitions, and axioms to support your argument. It is important to also check for any potential errors or flaws in your proof before considering it complete.
5. Can I use different methods or approaches to finish a proof?
Yes, there are often multiple ways to finish a proof. It is important to choose a method or approach that you feel comfortable with and that aligns with the given problem. However, be sure to clearly explain your reasoning and logic to ensure the validity of your proof.
  • MATLAB, Maple, Mathematica, LaTeX
