How to graph in Latex ?
  1. Nov 11, 2004 #1
    How do I plot graphs in LaTeX? Example sin(x) to begin with. :frown:
    Also, how do I insert pictures in LaTeX? Example, simple circuit diagrams.
    student :confused:
  3. Nov 11, 2004 #2
    graphic7
    You cannot actually graph in LaTeX. You can plot something for example in Mathematica, Matlab, or Gnuplot and export it to a JPEG or EPS file. Look up the \'figure' directive in the LaTeX documentation. 'figure' will allow you to include an EPS or JPEG file.
  4. Nov 21, 2004 #3
    What is the \figure syntax for including a .JPG file cause I personally haven' t been able to locate it for a while now.
    James
  5. Nov 21, 2004 #4
    Any suggestions, guys, I really need to know how to import .jpg files urgently.
    James
  6. Nov 21, 2004 #5
    I don´t know how to include .jpg, I only know how to include .eps. What I usually do when I have to include a figure is printing it to a file (PostScript printer), then convert it to .eps with Ghostview and then include the .eps-file. Not very elegant and a bit time-consuming but it works.
  7. Nov 21, 2004 #6
    you should use eps files because jpegs can't be scaled.
  8. Nov 21, 2004 #7
    ok but what' s the syntax for including a .eps file?
    James
  9. Nov 21, 2004 #8
    \documentclass{article}
    \usepackage{graphicx}
    \begin{document}
    \begin{figure}
    \centering
    \includegraphics{filename.eps}
    \caption{Caption goes here}
    \end{figure}
    end{document}
    I checked to make sure that I put the pictures (.eps) into the same directory (C:) as the other latex files I have been compiling.....the caption appears but there is no picture. The other files (no picture) compile just fine.
    IT SAYS LATEX ERROR: UNKNOWN GRAPHICS EXTENSION : EPS!
    Help, James ! :cry:
  10. Jul 2, 2008 #9
    This is the correct LaTeX code for including a figure:
    Code (Text):
    \usepackage{graphics}
    \begin{document}
       \begin{figure}
          \includegraphics{sin}
          \caption{\label{sin}The sine function.}
       \end{figure}
    \end{document}
    This assumes that your sin(x) graph is in a file called "sin.eps" if you use plain "latex", or in a file called "sin.pdf" if you use "pdflatex".
    You could create such a graph by several tools including GNUPlot, GRI, Asymptote, R, Octave, Excel, and GLE. In GLE, you would create a script like this:
    Code (Text):
    size 12 10
    begin graph
       math
       title "f(x) = sin(x)"
       xaxis min -2*pi max 2*pi dticks pi/2 format "pi"
       yaxis dticks 0.25 format "frac"
       let d1 = sin(x)
       d1 line color red
    end graph
    and save it as "sin.gle". Then you run the GLE program as follows: "gle -d pdf sin.gle" to create "sin.pdf" or "gle -d eps sin.gle" to create the "sin.eps".
    Finally, you run LaTeX on your ".tex" file to produce the final result. You can see an example of this using "pdflatex" here:
    http://www.gle-graphics.org/latex/graph.pdf
  11. Jul 11, 2008 #10
    Are you sure about the "\usepackage{graphics}"? Maybe there are couple of packages... In all my documents it "\usepackage{graphicx}".
    By the way, we can also specify which file exactly you want by entering the full name, like "sin.png" etc. If you have a priority of file types you want to use (lets say, png if available, otherwise eps, otherwise pdf), you can add after the "\usepackages"s part this line "\DeclareGraphicsExtensions{.png,.eps,.pdf}"
  12. Jul 11, 2008 #11
    alphysicist
    Both the graphicx and graphics packages are available. I have used both, but if I understand correctly, I believe graphicx can do more than the graphics package.
    You can use pstricks to include a plot of a sine curve (for example); it is "in LaTeX" in the sense that all you have to do is type in several lines in your TeX document. I have used it for function plots and data plots, among other things.
    However, if the issue is just to include a function plot in a document and you don't already know pstricks, I would agree with the advice in the above posts to use a separate plotting program (like gnuplot) to produce an eps figure, and then include the figure using the graphicx or graphics packages.
Similar Discussions: How to graph in Latex ?
  1. MacTeX vs LaTeX (Replies: 3)
  2. Latex in ereaders (Replies: 1)
Loading...
