How to integrate 4/(1+2x)^2?
  • Thread starter haiku11
I have to find the antiderivative of 4/(1+2x)²
New question: Find s(t)
2. Given variables and equations
a(t) = 4/(1+2x)²
v(0) = 0
s(0) = 5
∫4(1+2x)-2
= 4∫(1+2x)-2
= 4[(1+2x)-1/-1]
= -4/(1+2x)
But the correct answer has a -2 numerator.
New attempt: The integral of the first equation would be v(t) and it says v(0) is 0, but the equation says that it will be -2.
Answers and Replies
HallsofIvy
41,833
956
You are treating 1+ 2x as if it were a single variable- you can't do that. Use a "substitution" u= 1+ 2x. Then du= 2dx.
hunt_mat
1,741
25
You forgot to use the substitution u=2x, therefore du=2dx, and this will get you your -2 that you require.
tiny-tim
25,832
251
welcome to pf!
hi haiku11! welcome to pf! :smile:
another method is to use the chain rule …
d/dx = d/d(2x) times d(2x)/dx :wink:
Oh ok that makes a lot more sense.
Thanks so much for your help.
Edit: I didn't see the rest of the question and now I'm even more confused. I edited the original post to show the entire question.
Please Help!!!!!!
I assume you have found the integral of your original function. Remember the ∫a(t) = v(t) + C. since you are given v(0)=0, you are supposed to solve for C. So now what you have to integrate v(t) because ∫v(t) = s(t) + Ct + D. You are given s(0)=0 so that will help you find D. Good luck :)
tiny-tim
25,832
251
lets see …
∫4(1+2x)-2
= 4∫(1+2x)-2
= 4[(1+2x)-1/-1]
= -4/(1+2x)
first, you must write the dx at the end of each line …
∫ 4(1+2x)-2 dx
= 4 ∫ (1+2x)-2 dx
= 4 ∫ (1+2x)-2 dx/d(2x) d(2x)
(you could put 2x = u here if you wanted)
= 4 ∫ (1+2x)-2 1/2 d(2x)
= 2 [(1+2x)-1/-1] + constant
= -2/(1+2x) + constant :wink:
Related Threads on How to integrate 4/(1+2x)^2?
  • Last Post
19K
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
66K
  • Last Post
