How to integrate sqrt(16-r^2) from a to 4
  • Thread starter Thread starter ashnicholls
    Integrate
The discussion revolves around the integration of the function \(\sqrt{16-r^2}\) multiplied by \(r\) over the interval from \(a\) to \(4\). Participants explore various integration techniques and substitutions relevant to this integral.
  • Participants discuss the potential use of substitution and integration by parts. There is debate over the appropriate substitution to use, with suggestions including \(u = 16 - r^2\). Some participants express confusion about handling the \(r\) term and the limits of integration.
The conversation includes attempts to clarify the integration process and the implications of different substitutions. Some participants confirm the correctness of certain steps, while others express uncertainty about the conversion of limits and the treatment of the \(r\) term in the integral.
Participants are navigating the complexities of variable substitution and integration limits, with some expressing a lack of familiarity with the notation and methods involved.
ashnicholls
\int_a^4\sqrt{16-r^2}rdr
How do you integrate this?
Is it by parts, and then by substitution for the root bit?
Cheers Ash
If \int_{a}^{4}{r\sqrt{16-r^2}}dr is your integral, a substitution would suffice.
which one though? u=16-r^2
and then work r out in terms u, and then integrate by parts?
Cheers
Is the answer:
\frac{1}{3}(16-r^2)^{\frac{3}{2}}
with limits a to 4
ashnicholls said:
u=16-r^2
Yes
In a way, yes. What you actually do is differentiate the expression u = 16 - r2
There is no need for that...follow the steps mentioned above and you'll know why.
What so you just ignore the first r?
ashnicholls said:
Is the answer:
with limits a to 4
That is correct.
yes just worked that out on a website, but what happens to the first r then?
cheers
u = 16 - r^2
du = - 2rdr
Can you spot an rdr somewhere in the original integral? Also, remember, when you're making a change of variable, the limits change accordingly.
sorry isn't it minus \frac{1}{3}(16-r^2)^{\frac{3}{2}}
yes done it now thanks, but how do you convert the limits?
Yes, that's right. Sorry I missed that.
It can also be +, but then, the limits have to interchanged.
Well, you know how u and r are related. What values would u take when r has those values?
oh so the upper limit is very u = 16 - 4^2 = 0
and the lower limit is root(16 - u)
Yes
Why would it be that. Put r=a.
or yes course
so lower limit is 16 - a^2
So is this right if someone doesn't mind checking.
using u = 16 - r^2 which converts to
du = - 2rdr
so -du/2r = dr
so integral becomes
the integral of - (root u)/2 with lower limit 16-a^2 and upper limit 0
which converts to
the integral of (root u)/2 with lower limit 0 and upper limit 16-a^2
which becomes [((u^(3/2))/3] with lower limit 0 and upper limit 16-a^2
which becomes ((16-a^2)^3/2)/3
Is that right, I hope you all understand it,
I don't understand that tex thing very well.
cheers Ash
That seems right.
are you sure?
put r=4 sinx,then dr= 4 cosx dx,16-r2=16(1-sin{square}x).
proceed.Work it out & tell me
ashnicholls said:
are you sure?
Yes, he's sure! Aren't you? :approve:
That leads to a more difficult integral Did you notice the "r" outside the square root? The way he did it to begin with was completely correct.
sorry.he is right
  • · Replies 105 ·
  • · Replies 21 ·
