How to make homotopy smooth
  • Thread starter jostpuur
  • Tags
    Smooth
In summary, the conditions for f(t,s) to be equal to x_2(t) are that f(0,s) = x_2(0) and f(1,s) = x_2(1). Milnor proves that there exists a homotopy g:[0,1]^2\to G between the two paths so that for all s\in [0,1], the mappingt\mapsto g(t,s)is differentiable.
jostpuur
2,116
Let [itex]G\subset\mathbb{R}^n[/itex] be some open set, and [itex]x_1, x_2:[0,1]\to G[/itex] be differentiable paths with the same starting and ending points. Assume that there exists a homotopy [itex]f:[0,1]^2\to G[/itex] between the two paths. That means that the f is continuous, and the following conditions hold.
[tex]
f(t,0)=x_1(t),\quad f(t,1)=x_2(t),\quad f(0,s) = x_1(0) = x_2(0),\quad f(1,s) = x_1(1) = x_2(1)
[/tex]
How do you prove, that there also exists a homotopy [itex]g:[0,1]^2\to G[/itex] between the two paths so, that for all [itex]s\in [0,1][/itex], the mapping
[tex]
t\mapsto g(t,s)
[/tex]
is differentiable?
This seems a clear claim, but doesn't seem to come easily from the definitions.
I know in one dimension, there's a technique called smoothing. Choose a [itex]C^{\infty}[/itex] function s, and then you can "smooth" any function f by defining:
[tex]
\hat{f}(x) = \int_{-\infty}^{+\infty} f(t) s(x - t) \, dt
[/tex]
[itex]\hat{f}[/itex], I think, is a [itex]C^{\infty}[/itex] function. Generally, you'd probably choose an s that is only nonzero on a finite interval, like [-1, 1].
Maybe you can use a similar technique here to smooth your homotopy into a differentiable one.
there is a vast theoiry of approximating continuous functions by smoothere ones. going back now ov er 40 years mentally, is eem tor ecall the weierstrass theorem as generalized by marshall stone in this context.
the opriginal theorem said any ciontinuosu function on a clsoed bounded interval can be uniformly apporoximated by polynomials, generalizing one says that a subslgebra of continuous functions on a compact hausdorff space is nuiformly dense if it is constant containing, and separates points?
since the coordinate functions separate points, the algebra they generate, i.e. the polynomials, is dense in any square in euclidean space.
so you can approximate your homotopy by one that is smooth, but it is harder for em to see how to get it to equal your original functions on the nose at the extremes.
milnor considers such a problem in his little "topology from the differentiable viewpoint", when he deduces the continuous brouwer fix point theorem from the smooth one.
I was aware of something like this, but I thought it would still be problematic because the paths [itex]t\mapsto f(t,s)[/itex] could be very close to the boundary [itex]\partial G[/itex], and a careless smoothing could perhaps push the path out of G.
a smothing can be chosen to move the path arbitrarily little, so if the distance from the boundary is finite, e.g. if the path and the boundary are compact and do not meet, then that is not a problem.
the problem you raise is the problem. e.g. in bott-tu, they prove the theorem that any continuous map of manifolds is approximable by a smooth one and simply announce as a corollary that continuous homotopy classes equal smooth homotopy classes. this is not so immediate as your question shows.
i.e. it does show that the map from smooth maps to continuous ones is surjective on homotopy classes, but for injectivity one must show that two smooth maps which are homotopic as continuous maps, are also homotopic as smooth maps, and this does not follow instantly from the approximation result, as one needs to choose the homotopy so as not to move the initial and terminal maps at all.
i guess you have to prove that two smooth maps which are very close to each other are also smoothly homotopic. you probably use some trick like a mapping cylinder, using an auxiliary space which includes the domain space so as to separate points better...hmmmmm...look at the graphs?
i.e. if the graphs are near each other, then just smoothly project one graph down onto the other?
i.e. given two smooth maps of a rectangle into a rectangle, the graphs live in the product of two rectangles, so we can slide both graphs together along lines in the target rectangle.
then maybe patch these rectangles by a partition of unity?..mumble mumble...
1. What is homotopy smoothing?
Homotopy smoothing is a mathematical concept used in topology and geometry to transform a given shape or figure into a simpler and smoother version while preserving its essential features. It involves continuously deforming the original shape until it becomes smoother and more regular.
2. What is the purpose of homotopy smoothing?
The main purpose of homotopy smoothing is to simplify and regularize a given shape or figure without changing its fundamental properties. It can be used to study topological and geometric properties of shapes, as well as to make data visualization and analysis easier.
3. How is homotopy smoothing different from other smoothing techniques?
Homotopy smoothing is different from other smoothing techniques because it is based on topological and geometric principles rather than statistical methods. It focuses on preserving the essential features of a shape while smoothing it, rather than just reducing noise or errors.
4. What are the applications of homotopy smoothing?
Homotopy smoothing has various applications in different fields, such as computer graphics, image processing, data analysis, and shape optimization. It is also used in physics and engineering to study and analyze complex systems and structures.
5. Is there a specific method for homotopy smoothing?
There are various methods for homotopy smoothing, such as the heat flow method, the Laplacian method, and the mean curvature flow method. Each method has its advantages and limitations, and the choice of method depends on the specific application and the desired level of smoothness.
