Homework Help: How to prove this?
  1. Feb 14, 2017 #1
    Prove or disprove: let a and b be integers and let p be a prime number. If p divides ab then p divides a or p divides b.
    2. Relevant equations
    pk=a
    a=pq+r
    3. The attempt at a solution
    Contrapositive: if p does not divide a and p does not divide b, then p does not divide ab.
    p divides a for some integer k; pk=a
    p does not divide a for some integer q and r; a=pq+r
    If p divides ab and p does not divide a, then p divides b.
    gcd(p,a)=1; there exists integers u and v such that pu+av=1.
  3. Feb 14, 2017 #2
    FactChecker
    2017 Award
    To prove directly, rather than using contrapositive, apply the unique factorization theorem to factor ab and see where that gets you.
  4. Feb 14, 2017 #3
    Ray Vickson
    What tools/results are you permitted to know/use?
  5. Feb 14, 2017 #4
    What do you mean?
  6. Feb 14, 2017 #5
    Hello.sorry if this is wrong....I thought it would only work if a and b are greater than zero and one of a and b is greater than P? I also don't understand the question, sure if a and b are both negative(as it says are in integers) p can divide the product, but not both individually using other factors which are only primes? right? so to use the factorisation of primes, I think a or b > 0, and a or b > P
    assuming just using two lists of primes for a and b.
  7. Feb 14, 2017 #6
    Ray Vickson
    I mean exactly what I say. Have you already seen some theorems about integers, primes, etc.? Do you know about prime factorization? So, what material do you have available to work with?
  8. Feb 14, 2017 #7
    FactChecker
    2017 Award
    Good point. To give a complete proof, the possibility of negative numbers needs to be considered. I think that can be taken care of by proving it for all positive numbers and handling negative numbers as corollaries.
  9. Feb 17, 2017 #8
    haruspex
    That is not a necessary additional condition.
  10. Feb 17, 2017 #9
    Yes, I think I understand. Is it because a= b =p is not ruled out??
  11. Feb 17, 2017 #10
    haruspex
    No, it's because you are given that p divides ab, so (if nonnegative) you can prove that at least one of them is greater than p.
  12. Feb 17, 2017 #11
    Oh, I think that is what I meant originally but now I am not sure as I said a or b > p and then one of a and b > p.,
    thank you, i must study the basics again.
Have something to add?
Draft saved Draft deleted
