How to remove Ethanol from Gasoline?
  • I
  • Thread starter gary350
Water extraction do not need be done by equal volume of water, about 10-20% would be sufficient - of course in 2-3 portions. This is a kind of countercurrent extraction, which is optimal method in this case. There would be a problem with recovering ethanol from water, this is an example of hard industrial rectification (kind of fractional distillation). In laboratory mixtures case I would recommend direct distillation as boiling point of ethanol is 60 deg lower than start of gasoline distillation. In practice, commercial gasoline frquently contain a lot of lower and higher boiling substances, which complicates separation.
Best regards
zk
Mtbe is generally known as a solvent so maybe it would help
anorlunda
Staff Emeritus
Insights Author
8,584
5,468
Did you notice that the previous post in this thread was from August 2017? The original participants will probably have forgotten about it. Therefore, I will close this thread now.
Related Threads on How to remove Ethanol from Gasoline?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
