How to solve 4/3 sin(x) = x
  • Thread starter choob
choob
32
those above steps imo are unnecessary, all i need to know is how to solve 4/3(sin theta)=theta, thanks in advance!
Answers and Replies
8,174
Two things:
  1. Is your equation 4/3 * sin(theta) = theta or is it 4/[3 sin(theta)] = theta?
  2. You are not going to be able to solve your equation, whichever one it is, by algebraic means. The best you can do is to get an approximate solution.
8,174
The link you gave is broken, so I don't know what you meant to show me. In any case, what I said in post 2 still applies.
choob
32
its not broken, all you have to do is click on the address bar and press enter, as if you were typing the url in.
diazona
2,175
choob is actually right, you have to do something like copying and pasting the URL instead of just following the link. The site is probably trying to prevent direct linking.
Anyway, the PDF file doesn't change anything - there is no analytic solution. You would need to use a graphing calculator or a computer to find the answer. (There's probably some sort of series expansion trick or something you could use to get a good approximation by hand)
Cyosis
1,495
If it's 4/3 * sin(theta) = theta you can find one pretty obvious solution.
astarmathsand
freeexampapers has had a lot of bandwidth problems. We welcome direct linking and plan to have enough bandwidth to allow this.
icystrike
446
Hi Cyosis ! I took some time looking and pondering of the possible solution and i could not figure it out , I hope you can provide me of the partial solution. Thank you.
Дьявол
365
Can somebody explain what's the task?
icystrike
446
icystrike
446
i tried using maclaurin's series and i manage to work out with the answer of 1.28 but i guess it is rather tedious.
rock.freak667
6,223
31
Well you could use the Newton-Raphson iterative method and find an approximation.
icystrike
446
Yes indeed Newton Raphson method can solve and it is similar to taylor'series.
Is there any other method to solve this question algebraically?
Mentallic
3,798
94
No.
Yes, I was also quite dissappointed to hear that such a simple result such as the one you have presented has no means of being algebraically solved; but what can you do...
Suggested for: How to solve 4/3 sin(x) = x
  • Last Post
35K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
