DLxX
- 58
How do I solve for x in the following question? I'm pretty sure you have to factor, but how do I solve for x with two x variables?
4x^2 + x = 0
4x^2 + x = 0
To solve for x in an equation, you need to isolate the variable on one side of the equation. This can be done by using algebraic properties and operations such as addition, subtraction, multiplication, and division.
The order of operations when solving for x is PEMDAS (Parentheses, Exponents, Multiplication, Division, Addition, Subtraction). This means that you should first simplify any expressions within parentheses, then solve for any exponents, and then move onto multiplication, division, addition, and subtraction in that order.
In some cases, it is possible to solve for x without using algebra. For example, if the equation is already in the form of "x = number", then the solution is simply the number. However, for more complex equations, algebra is necessary to find the value of x.
If there are multiple x values in an equation, you can still solve for x by using algebra to simplify the equation and isolate the variable on one side. In some cases, the equation may have no solution or an infinite number of solutions, which can be determined by checking for consistency in the original equation.
To check if your solution for x is correct, you can plug the value of x back into the original equation and see if it makes the equation true. You can also use a graphing calculator to graph the original equation and the solution for x, and see if they intersect at the correct point.
