Homework Help: How to solve this differential equation?
  1. Sep 27, 2011 #1
    Assume NA = NAo exp(-t/a)
    Solve the differential equation:
    dNB/dt + NB/b = NA/a
    2. Relevant equations
    differential equations
    3. The attempt at a solution
    trial function: NB = C exp(-t/a) + D exp (-t/b)
    with initial condition: C + D = NBo
    I tried plugging in this and NA into the original equation, but was not able to solve for C or D...
  3. Sep 27, 2011 #2
    vela
    Staff Emeritus
    Education Advisor
    Show us what you got because what you described should work.
    Note that the D term will vanish when you plug it in because it's the solution to the homogeneous differential equation. This allows you to solve for C.
  4. Sep 27, 2011 #3
    Unfortunately I don't really have much experience with this kind of differential equation. After I substituted the trial function and C = NB - D into the equation, I got:
    [ -(NB-D)/a*exp(-t/a) - D/b*exp(-t/b) ] + [ NB-D/b*exp(-t/a) - D/b*exp(-t/b) ] = NA/a*exp(-t/a)
    how would you solve 'D' from this?
  5. Sep 27, 2011 #4
    vela
    Staff Emeritus
    Education Advisor
    You want to plug the trial function into the differential equation:
    [tex]\frac{d}{dt}(C e^{-t/a} + D e^{-t/b}) +\frac{1}{b}(C e^{-t/a} + D e^{-t/b}) = \frac{N_{A_0}}{a} e^{-t/a}[/tex]
    When you differentiate the first term, you'll see the e-t/b terms cancel out, which leaves only the e-t/a terms, allowing you to solve for C. Once you know C, you can solve for D.
  6. Sep 27, 2011 #5
    Ok, thanks for the insightful help, vela. This is what I got for NB, with D=NBo-C :
    NB = [NAo / (a/b-1)] *exp(-t/a) + [NBo - NAo / (a/b - 1)] *exp(-t/b)
    assuming this is correct.
