Homework Help: How to solve this recurrence
  1. Nov 17, 2014 #1
    If
    ##T(n+1)=T(n)+ \lfloor \sqrt{n+1} \rfloor , n \geq 1##
    ##T(1)=1##
    then
    ##T(m^2) = ? , m \geq 1##
    2. Relevant equations
    3. The attempt at a solution
    ##T(n)=T(n+1) - \lfloor \sqrt{n+1} \rfloor , n \geq 1##
    ##T(m^2)=T(m^2+1) - \lfloor \sqrt{m^2+1} \rfloor##
    ##T(m^2)= \sqrt{m^2+m} - ... - \sqrt{m^2+3} - \sqrt{m^2+2} - \sqrt{m^2+1}##
  3. Nov 17, 2014 #2
    jedishrfu
    Staff: Mentor
    It looks like you're trying to create a generator function T(n+1) where n+1 is m^2 so rather than juggle the formula as you did solving for m^2
    you could say n+1 = m^2 and hence n=m^2 - 1 and sub that in for each n
  4. Nov 18, 2014 #3
    Your saying it this way
    ##T(n+1) = T(n) + \lfloor \sqrt{n+1} \rfloor##
    ##m^2 = n + 1##
    ##T(m^2) = T(m^2 - 1) + \lfloor \sqrt{m^2} \rfloor##
    on solving it through recursion tree method I'm coming up with
    ##T(m^2) = m + \sqrt{m^2-1} + \sqrt{m^2-2} + \sqrt{m^2-3} + ... + \sqrt{m^2-(m^2-3)} + 1##
    Now how can we solve this equation
  5. Nov 18, 2014 #4
    rcgldr
    Note that the floor of the square root is being used:
    T(n+1) = T(n) + ⌊ sqrt(n+1) ⌋
    T(1) = 1.
    I'm not sure how you convert this into a recursion tree, but note the pattern for fs(i) = ⌊ sqrt(i) ⌋ for i = 1 to 25:
    Code (Text):
    i     :  1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
    fs(i) :  1  1  1  2  2  2  2  2  3  3  3  3  3  3  3  4  4  4  4  4  4  4  4  4  5
    There are three 1's, five 2's, seven 3's, nine 4's.
    Noting this pattern and converting into a sum for T(m^2) results in:
    T(m^2) = m + 1*0 + 3*1 + 5*2 + 7*3 + ... + (2m-1)(m-1)
    T(m^2) = m + sum i=1 to m: (2i - 1)(i - 1)
    Which is a cubic equation of the form:
    T(m^2) = a m^3 + b m^2 + c m + d
    You can calculate 4 sets of values for m and T(m^2) (m = 1, 2, 3, 4), then use linear algebra to solve for a, b, c, d. (In this case d is zero).
    Code (Text):
    |  1   1   1   1 |  | a |    |  1 |
    |  8   4   2   1 |  | b |    |  5 |
    | 27   9   3   1 |  | c | =  | 16 |
    | 64  16   4   1 |  | d |    | 38 |
    | a |   |  -1/6   3/6  -3/6   1/6 | |  1 |
    | b |   |   9/6 -24/6  21/6  -6/6 | |  5 |
    | c | = | -26/6  57/6 -42/6  11/6 | | 16 |
    | d |   |  24/6 -36/6  24/6  -6/6 | | 38 |
    | a |   |  4/6 |
    | b |   | -3/6 |
    | c | = |  5/6 |
    | d |   |  0/6 |
    T(m^2) = 4/6 m^3 - 3/6 m^2 + 5/6 m
  6. Nov 22, 2014 #5
    @rcgldr
    I agree with your approach, But please tell me how can we solve this equation
    ##T(m^2) = m + \sqrt{m^2 - 1} + \sqrt{m^2 - 2} + \sqrt{m^2 - 3} + ... + \sqrt{m^2 - {m^2 - 3}} + 1##
  7. Nov 23, 2014 #6
    rcgldr
    I'm not sure it's possible without the integer floor function keeping the pattern simple. It's a non-linear recurrence equation. Link to wolfram example:
    http://www.wolframalpha.com/input/?i=sum+i+=+1+to+n,+sqrt(i)
    A linear recurrence equation has the form T(n) = a T(n-1) + b T(n-2) + c T(n-3) ... . For example the Fibonacci numbers are T(n) = T(n-1) + T(n-2), T(1) = 1, T(0) = 0. These can't be solved, but can be converted into a matrix form:
    Code (Text):
           | 1  1 |
       a = | 1  0 |
           | 1 |
    f(1) = | 0 |
    f(i+1) = a f(i)
    f(i+j) = a^j f(i)
    Powers of the matrix can be generated using repeated squaring: a^7 = (a * a^2 * a^4).
Have something to add?
Draft saved Draft deleted
